Question about Brother IntelliFAX 4100 Laser Fax
WHEN SENDING A FAX, THE RECIPIENTS HAVE SAID THERE IS A WIDE BLACK MARGIN AND THEY CAN ONLY READ HALF OF THE PAGE. INCOMING FAXES ARE CLEAN - POSSIBLE PROBLEM?
    President:
  • Brother Master
  • 1,447 Answers
Yes your fax laser mirror is derty clean it and then solve your problem
Posted on Jul 05, 2009
  • 398 Answers
Your scan glass is very dirty or your CIS (contact image sensor)is bad. Make a copy on your fax and you will see what you send.
-Carl
Posted on Jul 07, 2009
We have a Brother 4100 Fax Machine. When we send a fax or make a copy, there is a black bar about 2" wide that shows up the length of the page. It does not appear on incoming faxes. I believe it is...
Make sure the **** glass is clean, use a micro fiber cloth to wipe the debris/old toner or white out off the glass. restart the fax machine. If it prints this black line from a copy and it is 2" wide after you have cleaned both the glass and the white reference bar, most likley the scanner itself has failed.
www.brother.ca for further assistance.
Jan 14, 2011 | Brother IntelliFAX 4100 Laser Fax
Black Stripe on outgoing faxes
If the stripe is a thin line, the scanner glass is dirty, if it is wide stripe you have a bad scanner block. EXPENSIVE
Jul 01, 2010 | Brother IntelliFAX 4100 Laser Fax
Thick black line down recipeints faxes
Your scanner glass is caked with ink or lint. Open front cover and clean with windex or rubbing alcohol.
Apr 23, 2010 | Brother IntelliFAX 2800 Laser Fax
PROBLEMS WITH CLARITY OF INCOMING FAXES /BLACK STREAKS DOWN ENTIRE PAGE/VERY HARD TO READ SOME OF THE INCOMING FAXES.RECENTLY REPLACED DRUM AND TONER/WHAT WOULD BE CAUSING THIS PROBLEM?
First, make a copy of something to determine if your machine is at fault.
Move the blue slider on the drum cartridge back and forth 10 times.
Oct 01, 2009 | Brother IntelliFAX 4100 Laser Fax
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
FAX received full of black stripes
If you are using upper tray to send the fax than kindly open the fax gently and clean the lens with some cotton and spirit and than try to send the fax you will get the best result. to open the fax unit gently refer the user manual or this open by lifting it up side and you can see the lens inside it so clean the same ok.
Dec 22, 2008 | HP LaserJet 3050 All-In-One Printer
Blank vertical stripes on incoming faxes
1st. Print a report. If the blank stripes are still there, you must remove the drum and t6oner combination and clean the laser glass located on the bottom of the machine.
If the blank stripes do not appear, then the fault is on the scanner of the sending fax machine.
Feb 25, 2008 | Brother IntelliFAX 2800 Laser Fax
Light print of incoming faxes, cannot read
are copies light too? if not then it is sending fax, but most times it is inferior ink or drum causing the problem sometimes damp paper (try printing on reverse side as well)
Oct 31, 2007 | Brother IntelliFAX 2600 Fax
Brother IntelliFAX 4100 Laser Fax Logo
261 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
