Routers
Problem for Routers
Generic problem for all Routers
Router issues
By smokeefe91 on Jul 02, 2009
I recently bought a Netgear wnr2000 wireless n router after my linksysg stopped working (I'd only had it a 1 1/2 years). Unfortunately, Istill seem to be having problems. When I tried to install using thedisk provided, it said it was not a recognized operating system(windows 64 bit), so I had to set it up manually. I did this usingthe network feature with Vista. It is connected correctly and all thelights on the router are on. The network map shows that my desktop andlaptop are present (it does say that desktop is connected throughswitch while laptop through router, which I found strange). My surfingexperience on the desktop which is wired directly to the router usuallyworks (sometimes fails); however, when my laptop tries to connect, mydesktop gets knocked off of internet. My laptop which is connectedwirelessly will show that I have a connection and will go to myhomepage. If I try to go anywhere else on the laptop, I get the ''pagecannot be found'' message. I do repeatedly seem to get the message thatthere might be something wrong with the DNS server (whatever thatmeans). I have tried several troubleshooting things including thesuggestion that I disable my DHCP broadcast. (If I need to change thisback I will as I only did this on the desktop). The internet connectsfine when directly connected to my desktop through just the modem w/othe router, so I don't think that is the problem. I do have mycomputer going through a DSL filter, but the telephone guy said thatshouldn't be a problem. I have tried removing it, but have foundlittle improvement. I am thinking about returning the router andtrying something else if there is not a fix out there. Thank you foryour help. I tried to supply as much info as possible.
I also want to mention that problems started shortly after Directv guyput in new HD receiver and dish. Not sure that would make anydifference unless he tampered with phone line.
Solution #1
posted on Jul 02, 2009
Not Rated)
Newsman2010
Rank: Master
Rating: 91%, 8 votes
Make sure there is a filter on the phone line that the DirecTV receiver plugs into as well as the one on your DSL modem line.
Also, I'd try to set up the router manually, bypassing the Vista setup. Follow the instructions here: ftp://downloads.netgear.com/files/WNR2000_SM_07May08.pdf and see if that helps.
I almost always throw out the setup disk and go with the web-based config, as I have more confidence in myself than an automated tool connecting to another automated tool. :-)
Was this helpful?
Yes
No
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,... (More)
Answer
ps3 wont conect to friends on maden 10 is wired derect to the modem and still reading nat 3 what do... (More)
Answer
just got a new modem from shaw and now my blitzz wireless is painfully slow. it is model BWA611sb
Answer
I have a e-machine d3123 and I bought a cradlepoint350 to get a wifi for the house and the e machine... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Routers:
Top Router Experts
Rank: Guru Guru
Solutions: 3587
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
