Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
Touch pad for water/ice/light not responsive
My ge profile side by side artica refrigerator is having issues with the touch pad controls for the water/ice/light on the door. The light stays on green steady above the water button, but when pressed the light goes off and the refrigerator stops running for a brief few seconds, to inlcude the temp readings inside go blank.....and then it comes back on. Same thing happens when the light button is pressed or when the lever to try to retrieve water or ice is pressed. The icemaker is still making ice....but no water or ice is coming out either.
SOURCE: GE Profile Refrigerator will not dispense ice.
see http://applianceguru.com/view_topic.php?id=13243&forum_id=1&jump_to=76889
Posted on Apr 03, 2008
  • 184 Answers
SOURCE: Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Posted on Apr 10, 2008
maklean
  • 1665 Answers
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Posted on Jul 27, 2009
  • 10865 Answers
SOURCE: ge profile artica not cooling
  • Is the thermostat knob turned to the proper setting? If not, reset it.
  • Next, see if the compressor motor is running
    The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
    If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
    • The compressor
    • The Thermostat
    • The overload, relay, or capacitor
    • The defrost timer
    • The condenser fan motor
    Posted on Aug 16, 2009
    We have a GE profile side by side stainless steel refrigerator. The control panel touch pad does not function.
    The electronics behind the touchpad may have failed. You usually change the whole panel/pod as a single item - could be expensive and perhaps something else has failed, so it could be a waste. First check all connections to it are dry and not corroded. if they are OK Try to buy a used panel/pod on ebay, then change it
    Dec 14, 2013 | Refrigerators
    Temperature in refrigerator will not stay set. It keeps getting colder. I have a GE Artica model PSS27SGMD. It is a side by side with ice through the door. It is +- 9 years old
    GE Artica had problems with the "Motherboards" originally installed. They have since switched manufacturers so my educated guess that is the problem.
    Jan 08, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
    I have a GE Profile refrigerator Model # PSC23MGTC it has an Artica Water & Ice dispenser on the freezer door, the ice will not come out, and noew the water works only when it wants to, I think I need...
    Cut and paste this Factory Service manual for your refrigerator.
    The troubleshooting guide will help locate the bad part.
    http://appliancejunk.com/ge/refrigerator/31-9072.pdf
    Aug 08, 2010 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
    GE Artica, pulsing lights
    Your refrig display , has lost communication , with the main control board , located , behind the refrig , behind an 8 " X 10 " panel . The control board , is easily replaceable , with 7 or 8 plugs , attached to it . The part number , for your board , is WR55X10942 . It runs about $150.00 .
    Dec 09, 2009 | GE Profile¿ Arctica® Energy...
    I have a GE Profile ARtica side by side. Ice maker is acting up
    The dispensor door not closing completely . Replace the flap solenoid and plunger behind the dispensor controls .
    Aug 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
    Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
    GE profile Artica side by side. I am getting a frost build up
    Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
    Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
    Ice and water working intermittently, makes ice, Artica PSS 26NG
    Go into the test mode and use 0 4 as the test code between the dispensor board and the main board .(communication test) Sounds like the main control board though .
    Jul 18, 2009 | GE Profile¿ Arctica® Energy...
    Refrigerators Logo
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    richie46
