1.Open liftgate before disconnecting battery.
2.Open hood, disconnect and isolate the battery negative cable.
3.Open liftgate.
4.Disconnect the power liftgate prop rod.
5.Remove liftgate trim panel
6.Remove the four retaining nuts to spoiler .
7.Gently lift spoiler off of outer liftgate panel.
8.Disconnect the CHMSL electrical connector.
9.Disconnect the washer hose.
10.Remove spoiler from vehicle.
11.If replacing spoiler, transfer CHMSL lamp to new spoiler.
12.If replacing spoiler, transfer washer nozzle to new spoiler.
SOURCE: the parking brake in my
Is it a "stick" in the console between the driver and passenger seats, or is it a pedal you push down? If it is in the center console, try starting the car, putting it from park into NEUTRAL with your foot on the brake, and pull up on the stick a little while pushing in the button. If the button goes in, push the handle back down, put the car back into park, and take your foot off the brake. I'm not real familiar with the Pacifica, so a description of the parking brake would help.
SOURCE: how to replace 3rd brake light
the 3rd brake light is mounted to the spoiler. you need to remove the spoiler from the liftgate to acces the mounting bolts and the wire clip. there are five points of attachment of the spoiler,four hex nuts (metric) and one snap clip. two are accessable when the liftgate is open, they are in the corners of the liftgate. two more are under the upper rear window interior trim. the interior trim is held on by snap clips. if you pry outward on the trim starting on the right side of the window and work your way toward the middle you will be able to gain access to the two other nuts. once you have removed all four nuts, then close the liftgate and remove the spoiler by lifting up to disengage the last attachment point (snap clip). you will then need to change the light by removing the two nuts and disconnecting the wire clip. re-instal is the opposite of above. make sure that the wire for the third brake light does not get pinched when installed. (mine was improperly installed from the factory and the wire was pinched and this may have been why there was an early failure of the light)
