It has a light in the drum. already checked voltage, thermostat, replaced main board and still does not work.
SOURCE: The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
SOURCE: dryer
Have you fixed this yet? It has been over 3 months since and I guess you might have already had it repaired.
SOURCE: LG dryer DLE 3733S control panel inop but light on
Check the power to the display panel after you have it removed. If there is no power check the lines to the control, If the power is present with no action on the panel then you will have to replace the board. It may be as simple as cleaning the board off, since it has been a intermittent problem in the past. hopes this helps Tim
SOURCE: Lg model #dle0332w dryer won't turn open it up
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
SOURCE: I have an DLE9577WM LG TROMM the check filter
my lg tromm DLE9577WM is not heating, other than that the dryer runs well
Hello & Welcome to FixYa
If you have already cleaned the vent then the
problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be
reset and replacing it is recommended repair. It is located on the blower wheel
housing inside the rear panel to the exhaust duct. You can test it for
continuity before replacing. Please get back to me if you have any other
questions.
Kevin
