Question about HP Photosmart C7280 Laser Printer
Photo paper draw on C7280
It wont take it in and just clicks loudly everytime i click ok
I had the same problem and ended up in a very long chat session with HP online. It was very helpful -- they basically had me reset the printer to the factory settings. Press and hold print photos and red eye removal for 3 seconds. The printer should show Mfg Commands and under that it shows Enter Special Key Combo. In a sequence press red eye removal then print photo then red eye removal. It should then show uiaux and Support VixxFN0724AR. Press the right arrow key twice. It should then show Resets Menu. Press ok. It will then say Country/Language Reset. Press the right arrow key till you get the option of semi-full reset. Press ok. The printer should turn off. Wait about 10 - 15 seconds and then turn the printer on.
I basically told you what the chat session person said. If that doesn't work, I highly recommend that you get online support (it should be free) via their chat support.
Posted on Jul 09, 2009
  • Gary Peters Sep 03, 2011
    We were having a problem with a c7250 that kept booting to a blue screen and then giving a B error code. We finally got it to start again by unpugging the power supply from the wall, When it came up we used "*" + "#" and "123" to get to the system menu. But in our case we went into boot options and choose user. It's seems to be back to normal now.
  • 484 Answers
Have you set the printer to accept the heavier weight paper?
Unless you have, it won't pull it in, as the rollers won't be ready for a heavier weight paper.
Do it in properties, before you print, so that the printer knows what is coming. Then your paper will transport through the priner.
-a.
Posted on Jul 02, 2009
When I copy to photo paper it reduces automatically, why
Print on special and custom-sized media
To print on special or custom-sized media (Windows)
1. Load the appropriate media. For more information, see Load media.
2. With a document open, click Print on the File menu, and then click Setup,
Properties, or Preferences.
3. Click the Paper/Features tab.
4. Select the media size from the Size is drop-down list.
To set a custom media size:
a. Click the Custom button.
b. Type a name for the new custom size.
c. In the Width and Height boxes, type the dimensions, and then click Save.
d. Click OK twice to close the properties or preferences dialog box. Open the
dialog box again.
e. Select the new custom size.
5. To select the media type:
a. Click More in the Type is drop-down list.
b. Click the desired media type, and then click OK.
6. Select the media source from the Source is drop-down list.
7. Change any other settings, and then click OK.
8. Print your document.
To print on special or custom-sized media (Mac OS)
2. On the File menu, click Page Setup.
Chapter 2
28 Use the device
3. Verify that the correct printer is selected.
4. Select the media size.
5. To set a custom media size:
a. Click Manage Custom Sizes in the Paper Size pull-down menu.
b. Click New and type a name for the size in the Paper Size Name box.
c. In the Width and Height boxes, type the dimensions and set the margins, if
desired.
d. Click Done or OK, and then click Save.
6. On the File menu, click Page Setup, and then select the new custom size.
7. Click OK.
8. On the File menu, click Print.
9. Open the Paper Handling panel.
10. Under Destination Paper Size, click the Scale to fit paper size button, and then
select the customized paper size.
11. Change any other desired settings, and then click OK or Print.
Print borderless
Borderless printing lets you print to the edges of certain media types and a range of
standard media sizes.
NOTE: Open the file in a software application and assign the image size. Make
sure the size corresponds to the media size on which you are printing the image.
You can also gain access to this feature from the Printing Shortcuts tab. Open
the printer driver, select the Printing Shortcuts tab, and select the printing
shortcut for this print job drop-down list.
NOTE: Borderless printing is not supported on plain media.
To print a borderless document (Windows)
2. Open the file that you want to print.
3. From the application, open the print driver:
a. Click File, and then click Print.
b. Click Properties or Setup.
4. Click the Paper/Quality tab.
5. Select the media size from the Size is drop-down list.
6. Select the Borderless Printing check box.
7. Select the media source from the Source is drop-down list.
8. Select the media type from the Type is drop-down list.
Print borderless 29
9. If you are printing photos, select Best from the Print Quality drop-down list.
Alternatively, select Maximum dpi, which provides up to 4800 x 1200 optimized
dpi* for optimum print quality.
*Up to 4800 x 1200 optimized dpi for color printing and 1200 input dpi. This setting
might temporarily use a large amount of hard disk space (400 MB or more) and will
print more slowly.
10. Change any other print settings, and then click OK.
11. Print the document.
12. If you printed on photo media with a tear-off tab, remove the tab to make the
document completely borderless.
Change settings from an application for current jobs (Windows)
To change the settings
1. Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
(Specific options may vary depending on the application that you are using.)
3. Change the settings that you want, and then click OK, Print, or a similar command.
Change default settings for all future jobs (Windows)
1. Click Start, point to Settings, and then click Printers or Printers and Faxes.
- Or -
Click Start, click Control Panel, and then double-click Printers.
2. Right-click the printer icon, and then click Properties, Document Defaults, or
Printing Preferences.
3. Change the settings that you want, and then click OK.
9. If you are printing photos, select Best from the Quality drop-down list.
dpi*.
print more slowly.
10. Select the media source. If you are printing on thick or photo media, select the
manual feed option.
11. Change any other print settings, and then click Print.
Nov 04, 2011 | HP J4680 Office Jet All-In-One Printer
I am getting white block on my prints(no color) when a print photos on a HPC7280. Using Windows 7.
Check if you are using Windows Photogallery to print or some other application... If not windows photogallery then right click on any of your picture, click on properties Click on 'Change' next to open with select windows photogallery from the list Click apply then Ok
Open the photo after that, click on print and on the window which opens up, click on the Options which is at right hand bottom corner A pop up windows would open up, click on printer properties and select the quality from Automatic to best Select the size of paper that you are using Then go to the advanced tab on the same window at the top and check the box which say maximum DPI Then try to print
Oct 24, 2010 | HP Photosmart C7280 Printer
How to load 4X6 photo paper
hi
  • Turn on the Epson 875DC and the attached computer. Make sure the cable between the two devices is securely in place.
  • Step 2 Remove any paper that is in the printer's feeder tray. Place the 4x6 photo paper printable side up in the tray, with the support sheet at the bottom of the stack of photo paper. Adjust the paper guides so they are pressed against the margins of the paper.
  • Step 3 Open the photos to be printed in your computer software program of choice. When you are ready to print the photos, click on the "File" link at the top of the window, then choose "Print." Click on "Properties" and select "4x6" for the paper size and "Photo Paper" under the paper type. Click "OK" to close the "Properties" window, then click "OK" again to print the photos.
  • Jul 02, 2010 | Brother MFC255CW All-in-One InkJet Printer
    HP photosmart 8250 wont print from photo tray.
    Follow these steps in the order presented to resolve the issue. Step one: Reset the product
    1. While the product is still on, disconnect the power cord from the back of the product.
    2. Wait 30 seconds, and then plug the power cord into the back of the product.
    3. If the product does not automatically turn on, press the On (c01453128.gif ) button.
    Step two: Check the condition of the paper and reload it
    1. Lift the photo tray lid.
    2. Slide the paper width guide all the way to the left.
    3. Remove the paper from the tray.
    4. Replace any ripped, dusty, wrinkled, or bent paper.
    5. Make sure that the stack of paper contains only one type of paper.
    6. Tap the paper stack on a flat surface to align the edges.
    7. Load photo paper with the print side down and short edge first into the photo tray. Slide the stack of photo paper forward until it stops. NOTE: If the photo paper has perforated tabs, load the photo paper so that the tabs are facing away from the product.
    8. Slide the paper width guide snugly against the paper. NOTE: Do not overload the photo tray. Make sure the stack of photo paper fits within the photo tray and is no higher than the top of the paper width guide.
    9. Lower the photo tray lid.
    10. Extend the paper catch.
    11. Try to print the job one more time.
    • If these steps resolved the issue , there is no need to continue troubleshooting.
    • If the issue persists , see the next step.
    Step three: Choose the photo tray in the print driver settings
    1. Open the document to print.
    2. Click File , and then click Print . The Print window opens.
    3. Click Properties . The Properties window opens.
    4. Click Printing Shortcuts , and then click the shortcut you want to use.
    5. From the Paper source drop down list, click the paper source.
    6. From the Size is drop down list, click the paper size.
    7. From the Type is drop down list, click the paper type.
    8. Click OK , and then click OK again to print the document.
    • If the issue persists , try the following Workaround.
    Step four: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Sep 08, 2009 | HP Photosmart 8250 InkJet Printer
    HP C7280 duplex scan problem
    IN XP
    click on start and select control panel.
    in control panel on the top left hand click on switch to classic view if is not there dont worry.
    Next Goto printers and faxes and then right click the printer icon and select printing prefrences and in the advanced tab make sure that duplex printing is enabled.
    IN vista
    Click on start
    in the start search box type "printers" and click on ok.
    Single left click your printer and then single right click your printer icon and single left click the option that says printing prefrences.
    in the advanced tab make sure that duplex printing is enabled.Now try to give the scan command and it will work as long as the paper is fed in from the adf it will be better
    May 29, 2009 | HP Photosmart C7280 Laser Printer
    HP Photosmart C7280 Paper Jams
    It isn't always about the paper. The video shows a few other things to check.
    May 04, 2009 | HP Photosmart C7280 Printer
    How do I select mirror image (reverse image) from HP Photsmart
    When you select Print and the Print window opens, select Preferences.
    Click on the Advanced tab. Look for the "Mirror Image" option. It should be "Off". If you click on "Off" the drop down menu should appear to change it to "On". Click "OK" at the bottom. Then click "Print" on the Print window.
    Don't forget to change it back when you are done. :-)
    (Note: If the Mirror Image option is not on the Advanced tab, look on the Effects tab.)
    Apr 22, 2009 | HP Photosmart C7280 Laser Printer
    HP c7180 message "Push output photo tray all the way down"
    I have the HP C7280 and I was able to fix the problem.
    HP seems to have 3 trays. The bottom tray is for the paper. The middle one has a small blue tray for the photos and the top tray is where the paper comes out.
    Well I lifted the top tray where the paper comes out (it can angle up) and then I clicked OK on the problem. I may have even rebooted, but then I got a new error message which is good. It said to push photo tray (the small blue tray) all the way in which I pulled out and pushed back in. Then I pushed the top tray down so all is flat again. I clicked OK and it re-calibrated with no more error messages! Hope this helps.
    Feb 16, 2009 | HP Photosmart C7180 All-In-One InkJet...
    I recently purchased a hp photosmart c7280 and want to know if i can print photos on 5x7 paper.
    Hi - You can download the manual by clicking the link underlined in blue below:
    c7280
    See page 105:
    So yes you can print 5x7 although 4x6 is recommended.
    Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
    Informatica
    Sep 06, 2008 | Office Equipment & Supplies
    Photo Paper Feed
    hi,
    the issue that you have might need to change some settings from the printing properties. WHen you hit on PRINT, a box will open, right? look on the top right of that box, you will see "PROPERTIES" or "Preferences" just click on it, then another box will open. Click on Printing Shortcuts tab, try to review the settings. And if you want to print using the main tray, it should set it to Automatic select or Main tray. And make sure that it sets to General Printing. But if youre going to print a photo, you will have options there to choose what type of paper when you click on that, the settings on the paper size, paper source, etc. will change also. For paper source, make sure that it sets to Photo Tray.
    If you will be able to open printing preferences, all options are there, you just need to read and choose which settings you want to use.
    Thank you so much.
    adonscott
    Jun 25, 2008 | HP Photosmart C7280 Printer
    HP Photosmart C7280 Laser Printer Logo
    2,703 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
