Question about Panasonic 2.4GHZ CORDLESS PHONE W/CALLER
Panasonic handset speaker phone
I have a panasonic KX-TG 2357S speaker phone. The phone works fine in making and receiving calls. However, the speaker stopped working.
Any way to fix the speaker?
  • 51 Answers
SOURCE: Transfering incoming phone calls Mod. Panasonic KX-T7730
do you mean call divert?
its possible.
we could do it.
Posted on Jan 17, 2008
SOURCE: adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Posted on Nov 22, 2008
  • 22 Answers
SOURCE: retrieving messages over phone
Using the answering system
1 Dial your phone number from a touch
tone phone.
2 After the greeting message starts, enter
your remote code The default setting is “11”..
LThe unit plays back new messages
including memo messages.
LAfter playing back new messages,
the voice guidance starts.
3 Follow the voice guidance as
4 When finished, hang up.
Voice guidance
During remote operation, the unit’s voice
guidance prompts you to press {1} to
perform a specific operation, or press {2}
to listen to more available operations.
Operations are presented by voice
guidance in the following order:
– Play back all messages
– Play back new messages
– Record your message
– Erase all messages
– Record your greeting message
LIf you do not press any dial keys within
10 seconds after a voice guidance
prompt, the unit disconnects your call.
LIf less than 10 minutes of recording time
is available, the unit announces the
remaining recording time after the last
message is played back.
Remote commands
You can select the desired line(s) and
press dial keys to access certain
answering system functions without
waiting for the voice guidance to prompt
1 Select the desired line(s) while you are
accessing the answering system if
For line 1: {#}{1}
For line 2: {#}{2}
For line 1 and line 2: {#}{0}
LAfter selecting the line(s), memo
messages do not play.
2 Press the desired dial keys.
Key Remote command
{1} Repeat message (during
{2} Skip message (during
{4} Play new messages.
{5} Play all messages.
{9} Stop recording/
{0} Turn answering system
{*}{4} Erase currently playing
{*}{5} Erase all messages.
{#}{1}{7} Record a greeting
message for line 1 only.
{#}{2}{7} Record a greeting
message for line 2 only.
{#}{0}{7} Record a common
greeting message for both
line 1 and line 2.
{#}{1}{8} Turn answering system
on for line 1 only.
{#}{2}{8} Turn answering system
on for line 2 only.
{#}{0}{8} Turn answering system
on for both line 1 and line 2
*1 If pressed within the first 5 seconds of a
message, the previous message is
*2 To resume operation, enter a remote
command within 15 seconds, or the
Turning on the answering system
If the answering system is off, you can turn
it on remotely by calling the selected line in
“Turning the answering system on” on
page 40.
1 Dial your phone number.
2 Let the phone ring 15 times.
LThe unit answers your call with the
greeting message.
LYou can hang up, or if you call from a
touch tone phone, you can enter your
remote code and begin remote
Posted on Apr 14, 2009
Remove all power (wall and batteries). Ensure that the phone line is active and properly connected. Did they used to work? If so, check line conditions. If not, return for exchange.
Posted on Nov 29, 2009
SOURCE: handset volume on Panasonic KX-TGA101S is too low
Thanks for the user manual. This is the only place online I could find it...the other manuals are for installation only. I learned to push the up or down arrow on soft keys to make volume louder or softer. They have changed the page number. I found this on page 16.
Posted on Jun 03, 2010
SOURCE: Panasonic cordless handsets all say line in use
Return to the manufacturer for replacement. I've spent hours on this and have had my line tested. It's a base station fault.
Posted on Oct 02, 2010
0 characters
1 Points
Panasonic phone#KX-TG-63215 manual
You may download a copy of the KX-TG6321S manual at
Battery information is on page 6.
The KX-TGA630 handsets use two rechargeable AAA batteries, which should be available at just about any department, electronics, or office-supply store.
Jan 02, 2014 | Panasonic KXTPA50 Phone
Can I register a panasonic kx-tg55438 handset to a kx-tg5622 base
No, The kx-tg 5622 uses only the kx-tga560 (2 of them) for its cordless sets
Jan 07, 2010 | Panasonic KX-TG5622 Phone
Panasonic CORDLESS
1st check that the charger is plugged and energized. It should light up when dropping a hanset into the craddle.
2nd Check that the batteries are connected properly inside the handset and that they have the full voltage. Try 1st step again
Oct 14, 2009 | Panasonic KX-TG1033S Cordless Phone
I have the kx-tg 4500 4 line base unit phone. Line one flashes but does not ring or display caller. The other lines work fine. The handsets show no activity ie they don't even flash if a call comes in on...
I had the same problem once, turned off the base unit from power cord and the phone line and all connected handset units, then turned it back on & it worked.
Aug 05, 2009 | Panasonic KX-TG4500 Phone
Suddenly have voice mail messages on handset (beeping before dial tone) when hooked to external voice message machine. I am using Vonage as my company.Panasonic hands free hooked to 4 handsets. Model is...
vonage gives you a personal voicemail. You should contact them and find out how to retrieve it first. If you have your companys voicemail on the panasonic you should also make sure that vonage voicemail get longer waiting time.
Jun 15, 2009 | Panasonic KX-TG5621 Phone
No ringer sound panasonic KX - TG 7200 BX
not that I am aware of . usually just buy a new phone and be done with the non functioning one .
Jan 16, 2009 | Panasonic KX-TGA101S Cordless Handset
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
check page 18 from your user guide (or at "" if you don't have the book), your security code may not be set. good luck!
Feb 26, 2008 | Panasonic KX-TG1100 Cordless Phone
Phones Logo
50 people viewed this question
Top Panasonic Phones Experts
Are you a Panasonic Phone Expert? Answer questions, earn points and help others
