Question about HP LaserJet 2100 Printer
Printer making noise
My HP LaserJet 2100 printer has started squeaking while it is printing.
What could be wrong and is there anything I can do about the problem?
    Problem Solver:
  • 6 Answers
I would try another toner cartridge. There is a drum inside of cartridge itself that turns also when you print.
Posted on Jul 02, 2009
    New Friend:
Typical cause is the toner cartridge (particular if it is a remanufactured cartridge). Toner can sometimes fuse to the parts, causing them to rub and bind.
Another common cause on those units, though, is the mirror motor on the laser scanner assembly. This issue may manifest as a high-pitched squeal, rather than a steady chirping (if that description makes any sense), and it will only occur while the printer is actually printing. If you get the squeaking during startup (when only the transport mechanism is running to ensure the all the gears and rollers turn properly), then the issue is probably not with the scanner motor.
Now, anything inside the scanner assembly is generally not considered to be a serviceable part. The only officially supported remedy is the replacement of the whole scanner assembly by a qualified service technician. However, since the 2100 is only a small-workgroup-class printer, replacing the laser assembly would cost you about as much in parts and labor as it would to get a newer-model refurbed printer.
But the 2100 is a real workhorse--designed to last. If you can alleviate this one problem, the printer may serve you another 5 years or more. [Then again, this question is almost 5 years old already.]
The following video (it's not mine--I just came across it in a search earlier today) shows how you might be able to resolve the problem yourself by lubricating the mirror motor, rather than replacing the scanner.
The operation might not be for the faint of heart, but the video is pretty detailed, especially for guiding you through disassembling the printer. You'll find that the housing of your 2100 is completely identical to that of the 2200 seen in the video. Removing the covers to get to the guts will be exactly the same, but the internals are somewhat different, due mostly to the 2200 having been redesigned to allow for the inclusion of a builtin duplexing unit on some models (such as the one in the video). The 2200 also employs a different scanner. I have removed scanners on both, but have never tried to take one apart on either, so I cannot say how they might compare.
How to fix high pitched squeal on LaserJet 2200DN
Posted on Mar 03, 2014
Hp printers 2100tn makes Noises when printing
check the noise level without toner. if it will be good, replace the toner cart.
Apr 17, 2010 | HP LaserJet 2100 Printer
HP Laserjet 2840 when operating is making a really bad squeaking noise, what do i need to do, is it just a case of removing all the colour laserjet cartridges and cleaning the printer and lubricating, when...
If you hear the noise when you power up when just the transport is running, you may need a new fuser. If the noise only comes during printing after the transport starts it could be a bad laser unit. The levels should not be changed by removing the cartridges.
Jan 05, 2010 | HP LaserJet 2840 Printer
My hp 2100 laserjet makes a sqeeking noise when it begains to print as if it is a roller, it works fine from the upper single feed with no noise please advise. Thanks
This could be caused by a worn and shiny paper seperator pad in the cassette tray 2.It sits at the front in the middle of the tray
Oct 12, 2009 | HP LaserJet 2100 Printer
HP Laserjet 4M Plus
That sounds like a problem with your printer driver to me. If the wrong driver is used, then print codes that the other device uses will not be interpreted correctly by your Laserjet 4M Plus, which will cause it to beep. Check the driver on your computer to make sure that you are using one designed for any of the following:
HP Laserjet 4
HP Laserjet 4+
HP Laserjet 4M
HP Laserjet 4M Plus
(Either the symbol "+" or the word "Plus" may be used but most commonly the + is the non-Postscript version and the word is used with the Postscript version. Just as an FYI, the only two differences between the M and non-M versions are the ability to speak Appletalk and the addition of the Postscript module, which is in one of the RAM expansion slots.)
Mar 29, 2009 | HP LaserJet 4 plus Printer
HP LJ P2015DN making noise/squeaking
As you mentioned that the printer makes loud grinding noise or squeaking when page comes out than i feel this is the noise coming out due to faulty fuser.
I want to be sure so please open the rear bin and try to print if still noise comes than i m sure it is fuser.
If there are smudges on the printed page or if some film coating is coming out with printed page than fuser roller are physically damage.
However in this case i assume fuser is faulty.
If there opening the rear bin noise goes off than top output rollers are faulty.
Thanks and Regards
Neeraj Sharma
Feb 18, 2009 | HP LaserJet P2015dn Printer
HP laserjet 2100 will not print PDF from Adobe Reader 9.0 correct
to print to pdf use software printers one can be found here
Dec 26, 2008 | HP LaserJet 2100 Printer
Print problem
How old is your toner cart?
Have you given the toner a little shake lately?
Is there paper wrapped around the fuser causing only a partial printout?
Jun 26, 2008 | HP LaserJet 2100 Printer
I want to reinstalled Laser Jet 2100 printer so what can i do
Apr 16, 2008 | HP LaserJet 2100 Printer
Squeaking noise when printing
This is a duplicate posting; here is the link to the active posting: http://www.fixya.com/support/t132706-squeaking_noise_when_printing
Feb 02, 2007 | HP Color LaserJet 5500hdn Printer
HP LaserJet 2100 Printer Logo
275 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
