Question about Canon PowerShot A430 Digital Camera
Comming too bright while talking photos
I am using CANON A430 now when i take photos during day time it comes too bright and i cant see the images properly pls give help to solve my problem
Try fixing your brightness withing the menu
Posted on Aug 10, 2009
t00nz
  • 4738 Answers
SOURCE: how to increase brightness in Canon Powersot A620 ?
Are you asking about brightness as viewed on the LCD, or are you asking about increasing brightness on the actual image taken? If it's the image, there are two special modes that you can select on your mode dial. They are "Night Scene", "Night Snaphot", and "Indoor". A description of both, along with your camera's other special settings, may be found here:
http://www.canon.co.jp/imaging/mode/camera/scene-e.html
"Night Scene" can be selected directly from the dial. It's the one showing a person standing under a star. Note that Night Scene should be used with a tripod to reduce the potential for blurriness.
"Night Snapshot" works almost as well, but does not require a tripod. It can be accessed by selecting SCN on the dial, and then pressing right or left with the selection buttons until it shows in the menu. The camera will remember this setting the next time you select SCN. I usually keep my camera always set to this setting so that I merely have to select SCN to use it.
"Indoor" works very well in those large rooms that may produce dark backgrounds when taking photos. It also does not require a tripod. It's accessed the same way as "Night Snapshot" (Select SCN, then right/left until selected). This is another good setting that I like to keep sometimes set in SCN.
Try all three settings, (and don't forget all the others too). Think you'll be impressed.
Posted on Feb 23, 2008
SOURCE: Canon Powershot A430 horizontal lines problem
have opened my camera. (it was useless anyway, right?) GUess what I found: in the lens-assembly there is a ribbon cable that controls the two solenoids, one of the shutter, one of the diafragm (or what it's called). This one is broken, the electric circuits are discontinued and so there is no control. It seems to be a design error since it broke exactly where the ribbon bends at 180 degrees almost with no place for a loop most of the focussing time. Can anyone find out where to find a NEW replacement ribbon cable? 847a466.jpg
Posted on May 03, 2008
robmcd27
  • 423 Answers
SOURCE: problem when taking images
Try this: Set the camera to shooting mode. Press the function/set button Scroll down to find the automatic exposure item Set this to 0 and press the function set button again.
Let me know how this works for you and let me know if I can help any further. If you like my response, please rate it appropriately and thank you for coming to FixYa.
Posted on Feb 20, 2009
t00nz
  • 4738 Answers
SOURCE: I am using canon A430 for 1 yrs bur from bfore 2
First make sure you are taking pictures in auto, and not in manual (make sure the mode selector dial is not on the little red camera with an M). If it's not...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Now the A430 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. Repeat as the fix recommends, but please note that there may be only a small hope that this will work as the shutter may be stuck in the open position. This is harder to get unstuck than a closed shutter.
If the above doesn't work, consider attempting Fix 5a listed on the web page. There is some risk of damaging your camera with this fix, that's why I hesitate to recommend it until last.
Posted on Jul 04, 2009
SS PAI
  • 55 Answers
SOURCE: My camera Canon PowerShot A430 have fine striped
it seems that certain pixels in the censor are damaged...
pls contact the manufaturer
www.canon.com
hope this helped...
Posted on Jan 05, 2010
How can i show the date during printing the picture?
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Sep 06, 2011 | Canon PowerShot A430 Digital Camera
HELLO , LANCE HERE (NEW ZEALAND) I HAVE A CANON POWERSHOT A430 ABOUT 3 YEARS OLD, ITS STARTED TO HAVE A PROBLEM ON OUDOOR SUNNY DAY PHOTOS, ALL THE PHOTOS COME OUT WHITE, OVER EXPOSED, SEEMS...
Probably the shutter flex cable is broken inside the lensblock,or replace the lensblock,labor extensive,technical skill required.
See other solutions for similar faults.
Jean
Jan 02, 2011 | Canon PowerShot A430 Digital Camera
Hiya - canon powershot a430 I need to know how I can turn the date on so it prints on my photos - can I do this on this camera?
Jul 23, 2010 | Canon PowerShot A430 Digital Camera
Overexposure
The A430 is prone to fatigue failure of a flex cable internal to the camera that causes these symptoms. Please see this other Fixya article.
Apr 08, 2010 | Canon PowerShot A430 Digital Camera
Canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear..
canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture there's a horizontal line appears in the picture..
Dec 21, 2009 | Canon PowerShot A470 Digital Camera
Photos come with horizontal stripes and too bright
Hello naushed,
I had the same issue with the white horizontal lines with myCanon Powershot series camera too. When taking pictures, I get the horizontal lines. In daylight, I almost cannot see the pictures because it gives me very bright output. In darker areas, the picture can still be toleratedbut white lines are still there. Although when I am taking a video,the quality is good.
I was able to read that there is one part insidethe camera's mechanism that is faulty. Its a CCD problem. You should bring this to a CanonAuthorized service center and they should replace and fix the faultypart, free of charge. I got my Camera fixed for FREE! I was able to do macro shots again.Trust me and go to canon. What I did is to print this advisory fromcanon itself. And show it to them.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
As part of their advisory:
"Effective immediately, and regardless of warranty status, Canon willrepair, free of charge, the products listed above exhibiting theabove-mentioned malfunction if Canon determines that the malfunction iscaused by the CCD image sensor. Canon will also cover the cost ofshipping and handling in connection with this repair.
Hope this helps.
Nov 18, 2009 | Canon PowerShot A430 Digital Camera
I am using canon A430 for 1 yrs bur from bfore 2 mnths when i image on day time the image becomes too bright and when i take at in light i comes parallel lines.i am beliving that u will suerly solve my...
Jul 04, 2009 | Canon PowerShot A430 Digital Camera
Problem when taking images
Jan 14, 2009 | Canon PowerShot A430 Digital Camera
Image too bright plus the white lines
Hi!
I had a similar problem with my powershot A430 recently. I took it to a canon service center and they identified the problem as "shutter unit problem". My cam was under warranty so they fixed it for free and also replaced my lens (even though i didnt ask for it!). :-)
Take your cam to canon; they will fix it. All the best!
-Aashish.
Aug 04, 2008 | Canon PowerShot A430 Digital Camera
Image result over bright at day light
Same problem here with the A430 I contacted Canon tech support and it looks like I'm going to be buying a new camera because it's not worth the effort and money to get it fixed. Rest assured, the new camera will not be a Canon.
May 24, 2008 | Canon PowerShot A430 Digital Camera
Canon PowerShot A430 Digital Camera Logo
231 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
