Question about MSI K8MM-V Motherboard
I do not know how to plug in the power connectors i cannot get sound whatsoever
  • TBairman May 11, 2010
    Which power connection?
All power connectors can be connected in one way only(they are sloted to be possibly install one way only), means you should not apply force when connecting them, just slip them, if they dont insert then flip them and install again. It will work.
Posted on Jul 03, 2009
Dishwasher is not turning on...no power
Make sure that the connectors in the power connector box are good. Sometimes they will burn off in the box.The door switches can go bad. the control can go bad. if a whirlpool some Amanas and kitchenaid modekls have a thermal fuse on the electronic board.
Oct 10, 2014 | Dishwashers
No sound whatsoever.
You have a blown speaker. Try plugging in a cab or connect another speaker of any kind to to see if you hear anything at all real low. Speakers blow in 2 different ways, they can either overheat, warping the voicecoil and end up sounding like a tin can or overheat and burn out completely, severing the voicecoil, leaving no sound at all, dead silence.
Mar 12, 2014 | Peavey Vypyr VIP 3 100W Modeling Combo...
Will power cord for ld3255vx work for ld4655vx wide screen tv?
Dear Cheryl,
The power cords are pretty standard from all theses TVs.
Please remember that these power cords have 3 pins (male side), being 2 flats and 1 round that connects to the wall. On the other side it also has 3 flat pins cast into the plastic/rubberized female side. These are standard power cables for the majority of the sound/video equipment you will find in the market.
If the connector at the TV (male) is of the same type in power cord you have (female), in other words, if it fits and completely locks in, then, YES! Go ahead and use it. There is no problem whatsoever.
IMPORTANT - BEFORE CONNECTING THE CORD TO THE WALL ("live" power), please test if your connector fits the TV set completely.
I hope I have helped you.
Dec 30, 2013 | Westinghouse " 46"" Class - LED - 1080p -...
Just changed the bulb, TV is about 7 years old. Anyways, I get no power whatsoever after putting in the new bulb. I have tried to unplug and plug back in. The manuel has a main power switch for the 65...
I think if possible a little more information:
master power if it has it will be on back of set and some models have safety switch so if back is off set will not power up.
Do any of the indicator lights (think this model has two) come on or is it total dead set?
No power whatsoever suggests no lights on front of set, let me know as much as you can,
I am in California and will be online for a while.
Steve, SD TECH
Oct 08, 2011 | Optoma RD65 65" Rear Projection HDTV
Computer just died.. no lights whatsoever. power
Take out the battery and try to start from the charger - if it's the same then you had a major hardware failure , most likely your motherboard has died. You need to take it to a repair shop for a precise diagnose and repair.
Jul 31, 2010 | Toshiba Satellite A215-S7422 Notebook
Dead
Check for the 5vdc standby voltage first, you must have at least this voltage before going any further. Look at the connectors for 5VSTBY or something like that. If you decide the power up the TV while working on it, you should plug the TV into the GFCI outlet for safety.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 10, 2009 | Vizio VW42LF 42 in. LCD HDTV
Model A3F cant start at all this morning. Press ON button but nothing happens no sound whatsoever.
If you are plugged into a power strip you might try plugging it directly into the wall. If there is an on off switch on the back of the machine near where the power cord plugs in, be sure it is in the on position. If this does not help, I would suspect a bad power supply in the computer. Not too expensive.
Jul 25, 2008 | ASUS Computers & Internet
No sound
be sure they are plugged into the right jack on back of sound card. Also, plug speakers into a second different PC with good working sound. This will verify that the spaekers are still ok. If speakers are ok, then check in control panel under Sounds, see if a sound cscheme is selected. If No Scheme selected, select one, then respond NO if prompted to keep scheme.
Apr 18, 2008 | Logitech Z-2300 Computer Speakers
Won't power on
Sounds like a blown fuse on the power board
Oct 05, 2007 | HP PSC 2410 All-In-One InkJet Printer
MSI K8MM-V Motherboard Logo
44 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
