I believe there is actually an access panel in front of the second row seat behind the drivers seat that you can access the top of the tank, fuel pump and possibly the fuel filter. Lift up the carpeting and check.
1. Remove the fuel tank cap to lower the fuel tank's internal pressure. 2. Locate access cover. 3. Remove the fuel pump & fuel filter assembly installation screws, then remove the fuel pump & fuel filter assembly from the fuel tank.
SOURCE: Where is the Fuel Filter in a Kia Sorento 2004 LX
THE FUEL FILTER IS IN THE FUEL TANK, THERE IS An ACCESS PANEL UNDER THE REAR SEAT CUSHION.
Testimonial: "Had conflicting info about location of it & was skeptical about doing it.Have 2 say it takes some skills 2 not break anything. Was successful, Thanks"
SOURCE: help me to locate the fuel filter and fuel pump in the kia sedona
start of at the gas tank look under neath there are some black lines running towards the engine follow it to a small gold color that ataches to the line you are following that is the filter the pump is in the gas tank you need to drop the straps at the tank to bring it down
SOURCE: 2004 Kia Sedona keeps stalling
Your problem sounds like you have a bad crankshaft position sensor. You will not get a trouble code (check engine light). This will cause the vehicle to suddenly stall. You cannot change the idle on this vehicle, or any FI modern vehicle contrary to a previous post. It is controlled by the engine management computer by way of an idle air control circuit on the throttle body.
