Samsung DVD-R130 DVD Recorder
Problem for Samsung DVD-R130 DVD Recorder
Samsung DVD-R130 will not load dvds, but will play CDs
By mamaof3girls on Nov 09, 2007
I have had this less than a year. It used to work fine. It started having problems more and more often reading discs, even when they weren't dirty. I have run a lens cleaner CD numerous times, and it seems to load and play CDs with no problem. But it will no longer load any DVDs I have tried, it tries to load, and then spits it back out saying that the disc cannot be read.
Same Problem
May 03, 2009
-   I have the same problem It will reject all discs saying disc cannot be read. I was thinking of getting a Samsung LED tv' But this has put me off Samsung for good-   Guest
Apr 29, 2009
-   I have only been able to record on my Samsung DVD-R130 Recorder two times since I bought it two years ago. Now it doesn't record and only plays some DVDs. Let me know if there is ever a recall on this product. -   Guest
Mar 13, 2009
-   same as all this player is a piece of ****, Samsung sucks! -   Guest
Mar 08, 2009
-   Samsun DVD-R130. Simply will not load DVD-RW or CD-RW. Insert disc and player will sit there trying to load, never will load.-   Guest
Feb 09, 2009
-   I record a tv show and dvdr130 will not load this disc. it just recorded ????
Seems to play x8 disc`s and record to 16x discs very intermittently ????
-   Guest
Best Solution
posted on Aug 31, 2008
Very Helpful)
pieceochit
Rank: Apprentice
Rating: 95%, 3 votes
I've gone through two of these machines in less than a year. They exhanged the first one because it stopped loading after a few weeks...the second one stopped loading dvd's after about 6 months. Now I'm out the money. Sounds like they must know this is a defect.
Comments:
Aug 31, 2008
- I have been through two of these machines in less than a year...the first stopped working after only a few weeks. It wouldn't load a dvd or anything for that matter. I was given a replacement, and guess what, after less than 6 month it too doesn't load. It's an obvious manufacturer defect. Won't buy Samsung junk anymore.
Was this helpful?
Yes
No
Solution #2
posted on Dec 05, 2007
Helpful)
ChrystalKaye
Rank: Apprentice
Rating: 90%, 13 votes
I am having the same problem with my dvd-r. It appears to record but when I try to playback the dvd it says please check disc. I know the discs are fine, I just purchased them. I called Samsung too. My recorder is less than a year old, so they said my warranty covers the parts but they would charge nearly $70 for the labor to repair it. This is my second time purchasing a Samsung the last one was a player and did the same thing. I figured it was cheaper to buy one with the recorder than to get the player fixed and try to buy a recorder separate. Anyway, now here I sit with two that do not work anymore. I do not plan on purchasing Samsung products in the future!
Was this helpful?
Yes
No
Solution #3
posted on Jan 04, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I repair these models everyday. The problem is cheap laser pickkup. I do align sometimes to make it work. But new dvd mech is no longer available from samsung.
Solution #4
posted on Mar 06, 2008
Helpful)
rpmcii
Rank: Apprentice
Rating: 83%, 4 votes
Add me to the list - my machine no longer reads regular dvds or dvd-r that I recorded. To make it worse the new Sony I bought does not read these dvd-r although it does record and play in that format? So I lost these recordings unless I can find some model that plays this verson of dvd-r - (i always thought dvd-r was a standard format?) The machine is a piece - was nice while it lasted for about 6 months - then would have to load the disc over and over after 10 tries it would read - now it reads nothing.
Was this helpful?
Yes
No
Solution #5
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
same just started not playing disks will be phoning samsung to see what they can do ..as they must no of this then watchdog will let you all no how i get on ..havehad this for about 2 years
but hardly ever use it ...
Solution #6
posted on Jan 05, 2008
Helpful)
ariablack
Rank: Apprentice
Rating: 93%, 7 votes
I just filed a complaint with Better Business Bureau against Samsung. Would anyone be interested in joining me in the complaint?
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #7
posted on Jun 07, 2009
Helpful)
herman50
Rank: Apprentice
Rating: 92%, 3 votes
I have had this problem too; apparently it’s to do with the laser head alignment, but if when I put the disc; as the disc try go in, I hold the flap down and as the disc being read, I put my small finger inside the slot and gently push the tray in a bit more. This seams to solve my problem. Good luck and make sure you wont get your finger jammed:-)
Herman
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #8
posted on Nov 21, 2009
Not Rated)
POS4U
Rank: Apprentice
Rating: 0%, 0 votes
The problem can be solved in the following manner:
1) Purchase 20 lbs sledge hammer
2) Carefully align Samsung R130 between feet
3) Take 2 steps back
4) Raise 20 lbs sledge hammer over head
5) Bring down with full force
6) Repeat
This may not repair it but I guarantee you will feel better.
Was this helpful?
Yes
No
Solution #9
posted on Nov 17, 2009
Not Rated)
rdesoto
Rank: Apprentice
Rating: 0%, 0 votes
I gave up on recording any more DVD's so just used it to view. Now it will not eject the last DVD I inserted (commercial DVD, not a recorded one). Totally stuck, will not eject at all. I may open it up just so i don't loose the disc. After that, my solution is a SLEDGE HAMMER!!!
Was this helpful?
Yes
No
Solution #10
posted on Apr 29, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
This DVD recorder is a piece of ****
Popular Solutions for Samsung DVD-R130 DVD Recorder
Questions and Unsolved Problems for Samsung DVD-R130 DVD Recorder
Do you recommend Samsung DVD-R130 DVD Recorder?
Answer
Answer
I put a dvd in and played it now the drive will not open. When I press the open/close button nothing... (More)
Answer
when i use a blank dvd-r disk the system goes to 'hold' and then simply ejects the disk
Answer
El disco no RECONOCE Cuando se programa para grabar
Answer
My dvd-r130 display shows nodisk when I close the bay door. What is the problem? Is it the optical... (More)
18 Other Users Have The Same Problem - Continued
Comment by thejoker37, posted on Jan 19, 2009
typical, I have the same problems with this stupid recorder ever since it was bought ( got it free with the TV). Sent it to Samsung repair centre recommended by their site and they upgraded the firmware.. and guess what!!! when they sent it back it still did not work - what a pile of ****. Updated the suggested firmware and it did bugger all. It's about time someone sue these people for producing i
tems that are not fit for purpose. Also any movies you record on any samsung players might not play on other recorders. much I found out after sending out 10 dvd's to customers.
Comment by farmtechie, posted on Jul 29, 2008
Have exactly the same problem, now realise that mine probably lasted longer than many. If anyone is still running complaints would be happy to join in as our machine has hardly been used.
Comment by Guest, posted on Jun 19, 2008
It wont play a brand new movie dvd. It is not a problem with dirt or scratches. It just spits them out.
Comment by Guest, posted on Jun 13, 2008
mi DVD-R130 no funciona bien, p`rimero comenzo pidiendome unos numeros para conformar una clave, la que busque en el manual y no existe y ahora ni siquiera me reconoce los DVD que le coloco y me dice que compruebe el DVD, el que comprobado en otro equipo anda perfectamente
Comment by Scottjr, posted on Apr 27, 2008
Can not load dvd's - says there is an error loading disc
Comment by Guest, posted on Jan 28, 2008
Samsung DVD-R130, Used very little, right in the middle of movie, Jason Bourne leaping off of a building with bad guys shooting at him, DVD stops, says can't read disc, then drawer opens. Opened it up, cleaned it, put back together, does the same thing with all DVD disc. Any suggestions beside chunking it?
Comment by Guest, posted on Jan 08, 2008
I have samsung DVD player (DVD-M108). It loads DVDs/CDs but does not read or takes too long. Then the display appears saying this disc cannot be played.
Comment by Juice1, posted on Jan 02, 2008
Had the R135 for less than a year, and probably burned less than 4 discs I've tried cleaning and using canned air, I'm pretty sure that the Loader Assembly is the culprit. In the past I've had OK luck with Samsung, but in the future will make them my last option.
Comment by nemery, posted on Jan 01, 2008
We had the same problem. Got our Samsung R-130 for Xmas 2006. Now Xmas 2007 it no longer recognizes any discs - spits them out and says to check the disk. Even immaculate new movie DVDs do not work. It was a problem that developed over time - we thought it was scratched discs- we bought a cleaning disc and it was no good. I took it apart and cleaned all parts with ethanol and no improvements - so it's not an issue of dirtiness. The lack of support the rest of you received indicates Samsung is washing their hands of this rampant problem - very poor service. I'm never buying their crap again. What a waste! If anyone else figures it out please post - we would be very grateful.
Comment by xploder, posted on Dec 30, 2007
i had mine for just over 3 months and it wouldn't load DVDs anymore. i really liked Samsung products but i am not too sure anymore I agree that they should do something about it.
Comment by ariablack, posted on Dec 18, 2007
I bought my Samsung DVD-R135 less than a year ago. It doesn't play DVDs anymore. I called Samsung, and they told me to buy a DVD cleaner, and I did, but it didn't help at all. So, I wasted more than $10.00 on a DVD cleaner for nothing. It is no longer playing DVDs. Samsung also told me it would be $70.00 for labor. After 3 months, labor is no longer included. I am thinking about filing a complaint with BBB. Would anyone else be interested in joining me?
thanks
Comment by sma132, posted on Dec 16, 2007
I have the same problem with DVD R-130. It keeps on giving the Disc can not be played error while the same disc plays fine in my other DVD player. I have also contacted Samsung and their response was tthat hey ship more than million units and 1-2% are going to be defective. So much for customer service. Looks like that this is a design flaw if many folks are having the same issue.
Comment by torifan, posted on Nov 21, 2007
Hello, I have the same DVD player and am experiencing the same exact problem. I cannot play any DVD's at all! It is extremely frustrating. Everytime we load a disc into the player, we get a message that says "disc cannot be played". I have tried to contact Samsung about this problem several times and they have been no help at all. They will not even provide you with a number for the corporate offices. I have had this player for under a year as well.
Describe your DVD Players problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
in , MD
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
