Question about Amana AFD2535DES French Door Refrigerator
COMPRESSOR DOES NOT RUN
HI, I HAVE A Amana AFD2535DES French Door Refrigerator, AND IT HAS A PROBLEM. THE COMPRESSOR CAN NOT START PROPERLY AND WORKS NORMALLY.
AFTER TWO OR THREE OPERATION HOURS, I CONSIDER IT WORK OK, BUT LATER ALL THE UNIT GET WARM AND EVERY 7 MINUTES I HEAR A NOT NORMAL NOISE. IT SOUNDS LIKE A SMALL SAW.
IF A LET THE UNIT REST FOR ONE HOUR IT WILL WORK FINE AT THE BEGINNING BUT IN FEW HOURS COMPRESSOR CAN NOT WORK AGAIN. IT NEVER RUN PROPERLY.
  • 400 Answers
I think your fridge has a blockage in the system which can be caused by migration of refrigeration oil. The compressor comes on but then the system blocks up and the compressor cuts out on overload and there is no cooling action. You need to have the system flushed by a professional
Posted on Jul 02, 2009
Clicking and buzzing every few mins, freezer unthawing
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 02, 2011 | Amana AFD2535DES French Door Refrigerator
Fridge & freezer warm , temp control panel lights up interm when door opened , compressor will not start , compressor start capacitor replaced recently where to start
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 24, 2011 | Amana AFD2535DES French Door Refrigerator
AMANA AFD2535DES. refridgerator and freezer quit working. I cleaned the coils. they were really dirty.
heatman101
Jan 29, 2011 | Amana AFD2535DES French Door Refrigerator
Doesn't seem to be working, unplugged, replugged. Heard knocking noise.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 06, 2010 | Amana AFD2535DES French Door Refrigerator
Just starting not keeping things cold
If there is frost on the wall of freezer, you have a defrost problem, and not enough air is circulated due to frost build-up. If no frost and all fans and compressor is running, you have a sealed system failure. Time to replace refrig.
Jul 02, 2010 | Amana AFD2535DES French Door Refrigerator
My refrigerator is not cooling anything but my freezer works fine
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
Thanks
Jul 02, 2009 | Amana AFD2535DES French Door Refrigerator
Amana DRB2101Aw1
heatman101
yhffg
Aug 06, 2008 | Amana AFD2535DES French Door Refrigerator
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Amana AFD2535DES French Door Refrigerator Logo
278 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
