Question about Canon PIXMA Pro9000 InkJet Photo Printer
Have a 1 year old Pro9000 thats starting to give
Have a 1 year old Pro9000thats starting to give small patches of black on the final part of an a4 sheet (colour bleed out on all edges) and suspect that the waste tank is full, Used to use i990 which had to go back to Canon. Is there any way I can empty/replace or reduce amount in the waste tank please ...
Thanks for your help
Stewart
    President:
  • 2,306 Answers
Use a Q-tip and a little water to wipe the wiper assembly on the right side of your machine. Unplug the printer when the carts are in the middle and look to the right with a flashlight. The wipers are supposed to wipe excess ink from the bottom of the printhead.
Posted on Jul 02, 2009
What is the calibrating code of toshiba e studio 2303a
(1)While pressing [0] and [5] simultaneously, turn the power ON. ? Adjustment Mode
(2) [SETTINGS] ? [USER FUNCTIONS] ? Select [DRAWER] ? Select [DRAWER1] ? Set the paper size to A4/LT. ? [OK] ? Set A4/LT for the paper in upper drawer.
(3) [CANCEL] ? [CANCEL] ? [SETTINGS] (Return to code entry screen.)
? [10]? [SETTINGS]? [START] (A gamma adjustment patch chart is printed out.)
(4)Place the patch chart for adjustment printed in step (3) face down on the original glass. Place the chart aligning its black side of the gradation pattern against the original scale.
(5)Key in a code "7165" and press the [START] button.
(6)If process finishes successfully, select "Yes" and press the [OK] button to apply the adjustments. (To cancel the reflection of adjustment results, press the [CANCEL] button.) In the case of an abnormal ending, "Error" is shown.
Press the [CANCEL] button to clear the error display. Next, confirm that the patch chart is oriented correctly on the platen and not at an angle, then do the process from step (4) again.
(7)Press [20] ? Press [SETTINGS] ? Press [START].
Notes:
•Compare with chart output in step (3), there should be no differences in patterns and no faint colors.
(8)Place the patch chart for adjustment printed in step (7) face down on the original glass. Place the chart aligning its black side of the gradation pattern against the original scale.
(9)Key in a code "7167" and press the [START] button.
(10)If process finishes successfully, select "Yes" and press the [OK] button to apply the adjustments. (To cancel the reflection of adjustment results, press the [CANCEL] button.)
In the case of an abnormal ending, "Error" is shown. Press the [CANCEL] button to clear the error display. Next, confirm that the patch chart is oriented correctly on the platen and not at an angle, then do the process from step (9) again.
(11)Turn the power OFF.
Sep 04, 2016 | Toshiba Office Equipment & Supplies
20 year old Maytag jetclean model WU482 small hole in front bottom of tub leaks water
At 20 appliance years of age, your Maytag may start leaking like a sieve but you can try patching the hole you see and hoping for another 20 years.
Jun 19, 2017 | Dishwashers
I have a problem with World War 3 Black Gold. I've just installed it on my PC. I'm using Windows 7 Ultimate 64bit and the game won't start. I double click on the WW3.exe, small black screen...
I had the same issue and resolved it by downloading the World war 3 black gold 1.2 Patch - install this and you should be fine. I will still ask you to select a resolution but it will actually let you now.
I got mine from here
http://www.shacknews.com/file/454/world-war-iii-black-gold-12-patch
Sep 19, 2011 | JoWood Productions World War 3: Black Gold
Black patches start blinking on photos played back
You're seeing blown-out highlights. These are the portions of your pictures which have been overexposed so much that all detail has been lost. If printed, they will show up as pure white, without a hint of shading.
The "correct" fix is to reduce the exposure by using exposure compensation to bring back the details. Blocked-up shadows (the same thing at the other end of the brightness scale, where dark objects go pure black) is generally considered less harmful to the final image.
That was the long answer. The short answer is: Press up/down on the multiselector to cycle through the different views available.
May 28, 2010 | Nikon D80 Digital Camera with 18-135mm...
My lexmark printer x1150 prints blank pages.What is causing this?
a 99% chance your ink cartridge is empty or dried out and blocked. If the printer has had plenty of regular use then I'd go for a new cartridge. If it's a new cartridge which hasn't been used for a few months then it's more than likely a dried out and blocked cartridge. A small trick I've used for years is to get a dried out cartridge reworking is to run your water tap with a small but steady stream of warm water running in a continuous flow (not gushing and not dribbling) over the golden patch on the underside of the cartridge. When you first start you will notice the water run off will be black (if it's the black cartridge of course) then it will clear and when it finally starts to loosen and clear the blocked jets the water will start running black again. At this point stop, gently pat dry the underneath of the cartridge and put it back into the printer. Now print out a page of text. A few jets may still be blocked and you may have to print 6 to 10 pages until it completely clears but it will leave you with a printout like a new one at no cost. I've told this to many friends and the only people it never worked on were the people who had empty cartridges to satrt with.
Some Techs may frown at this but I assure you it works and there is simply no other way to get printing again unless you replace the cartridge. Just remember not hot but warm water in a gentle flowing continuous stream. and only on the gold patch on the underside of the cartridge. It's not a myth it works. I've been doing it for years and always kept it off the net until now.
Apr 21, 2010 | Lexmark X1150 All-In-One InkJet Printer
Patch for tiny holes in fiberglass tub (8 yrs. old)
From my own experience I had a crack in mine. I sanded the area I wanted to patch. I bought a fiberglass repair kit from the hardware store. I mixed the hardener with the resin and applied it without the cloth. Make sure you have good ventilation and don't get it on your hands. After it dried I sanded it smooth it didn't look the best so I hit with a little spray paint. I have since replaced the tub but it held until I was ready to do that. A couple of years. Hey if this helps give me a vote please.
Mar 03, 2010 | Home
No audi sat nav code
i found a shop that can finally decode my audi navigation plus an only charged £50. not even the dealers can give you the code
the address is
Tech 2 Car Audio Repair Centre
322 Hobmoor Rd
Small Heath
Birmingham
B10 9HJ
Tel 0121 785 1700
Jun 05, 2009 | 2004 Audi A4
Problems with Skype and Logitech QuickCam Pro9000, when trying videochatting. I can see and hear the person I talk to, but can´t get my webbcam to connect with Skype. In the small window, where I should...
if you have the correct driver ...and it works on other instant massaging programs..like yahoo messenger or so...it means that the problem is from settings and so ...and its nothing wrong with th ecamera ...so ..try to reinstall skype ...
Apr 08, 2009 | Logitech Quickcam Chat Webcam
Ice Maker quit making ice cubes
Look on the bottom of the rectangular motor housing for the ice maker. This is the white box that holds the front end of the ice tray. In the past, this was normally a small patch of black 'runner' that covered the switch and helped kkep moisture out.
If you cannot locate it by feel, try using a small mirror and a flashlight to help you locate it.
Jan 02, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Screen trouble
This could be clusters of dead pixels in the monitor, although there is nothing that can be done as the screens are normally too costly to replace.
Feb 16, 2007 | Evesham Voyager 6400 Notebook
Canon PIXMA  Pro9000 InkJet Photo Printer Logo
102 people viewed this question
old marine
old marine
