Question about DVD & Blu-Ray Players
Toshiba D-VR650KU vcr/dvd video recorder
I have a Toshiba dvd/vcr combo that I have hooked up to a satellite reception. I have finally been able to figure out how to get picture to come up and to be able to watch a video or dvd, but cannot program the recorder channels because it is showing only cable/tv to do this and without cable or satellite, I only get about three local channels, so I cannot record.
Can you help me get around this?
Thank you.
Re: Toshiba D-VR650KU vcr/dvd video recorder
I talked to some very nice people at tech support 1-866-583-7353 and found out that my satellite reciever must be set to 480i, which of course is a pain since like I wanted High Definition. The composite a/v cables (red, white,yellow) are not high def and are part of the reason. I have TiVo and when recording a movie from TiVo to the DVD it states there as well to set the reciever at 480i. Once I did this I was able to record from the Sat to the DVD. I did a quick review and I couldn't find a combo set or just a dvd recorder that has component video cable (red,blue,green) or HDMI inputs at all, I'm thinking that all would have to be recorded at 480i.
Posted on Dec 22, 2007
0 characters
3 Points
How to use without remote
UPC 961613194763 053818570722
  • HDMI Output (rear), Remote control, Plays DVD Video, DVD_R/RW (VR format), DVD-R/RW (Video format), CD-R/RW, Audio CD, MP3)
  • 1080 Up-Conversion, Progressive Scan Video Out
  • Five Speed for up to 6-Hours Recording, Dolby Digital Stream Out
  • 2-Way Dubbing (VCR > DVD, DVD > VCR), Satellite Link Recording, S-Video Input / Output
  • Dec 02, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
    Since change over to digital dvd/vcr Toshiba SD-37VB does not record on Video tapes. What do I need to do to correct this or do I need to purchase some additional unit?
    Subcribe to cable or satellite tv services.Ur dvd/vcr unit will able to be used to record on VHS tapes again.Because cable or satellite tv services the tv incomming broadcasting tv signal still do broadcasting comming in as analog tv signal for the analog devices as analog devices require as it needed.
    Apr 27, 2011 | Toshiba SD37VB DVD Player / VCR Combo
    When we record our vcr to dvd rw on our combo the dvd will not play on any other dvd player
    You have to go into your tools menu on your dvd recorder and finalize the disk to make it compatible with other players, hope this helps.
    Oct 30, 2009 | Toshiba D-VR4 DVD Recorder/VCR
    We recently purchased a toshiba recorder/vcr combo d-vr610 and it plays dvd's with no problem but we tried to watch a video and we couldn't get a picture. I can't find the manual to see what I need to do....
    The DVD will play through component, composite, or HDMI, but you have to hook the VCR up separately with component cables - look at the back of the combo, you'll see where it says "VCR". That's where the cables have to go. Pretty silly, but I had the same problem, and this is the only solution I could come up with.
    Jul 04, 2009 | Toshiba DVR610 DVD Recorder/VCR
    Magnavox dv225mg9 dvd/vcr player. Hooked it up to TV/Cable receiver/combo and I get great dvd reception sound and picture, but on the vcr I get only sound
    I had the same issue. You probably have your unit connected with the newer cables that are red, blue and green. These are more sophisticated and offer better quality for the DVD portion. However, they will not carry the video for the VCR, only the audio.
    You need to connect a *yellow* Video Out cable from your DVD/VCR to the Video In on your TV, this should carry the video for the VCR! Hope this helps!
    Sep 30, 2008 | GoVideo Go Video DVD/VCR Combo
    first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
    cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
    click below for more information in hooking up:
    DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
    Good luck ,and Thank you in advance:
    Jul 15, 2008 | DVD & Blu-Ray Players
    Toshiba VCR/DVD Recorder Combo - Problems connecting it to system
    I was able to connect to my cable box. I used RCA (yellow, red, white) cabling. I connected the Video Out on the cable box to the Video In on the DVD/VC (to the DVD VCR cabling section). I then from same section used the Video Out using RCA Cabling to the the Video In connectors on my Phillips LCD TV. That left only to connect the TV to the cable box using regular TV coax cable. Everything works, although I am going nuts trying to dub from VCR to DVD-R or +R discs.
    May 21, 2008 | DVD & Blu-Ray Players
    Toshiba D-VR650KU can't "see" digital channels
    On the Notification screen with Cable highlighted I found that left clicking on Cable gave a drop down menu with TV on it for selection. The manual says that while Cable is highlighted, use the up or down arrows to get TV to be an option and then select it and Yes and enter. Hope this helps. I have other problems with my monitor on Line Out, the screen oftens turns blue indicating low or no video using Line 1 or 2 inputs.
    Feb 21, 2008 | Toshiba D-VR650
    Can't get VCR to record
    You may have to push the channel buttons on the source and check the video unit until you see whats playing on the main unit once you have a picture comming thru you should be able to record. if not let me know we can figure out some other solutions to get you up and recording.
    Dec 14, 2007 | Toshiba SDV395 DVD Player/VCR
    Finalizing DVDs of a previous burner
    Neither will work. you will have to try a computer.
    Oct 28, 2007 | Philips Magnavox MWR10D6 DVD Recorder
    DVD & Blu-Ray Players Logo
    494 people viewed this question
    Top DVD & Blu-Ray Players Experts
    Are you a DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
