Question about Microsoft Computers & Internet
Zpmqxk.dll problem... what is ''zpmqxk.dll'' all about? and i have some error about that. my laptop says that zpmqxk.dll can't be accessed. how can i fix it? thnks.
  • 818 Answers
Go here for find your driver
http://www.dll-files.com
Sergio
Posted on Jul 02, 2009
On my windows 7 gateway laptop I am receiving the message "the ordinal 572 could not be located in the dynamic link library iertutil.dll. I ran a cmd scan and did not find anything. Any suggestions?
How To Fix Iertutil.dll Errors
Important: Do not download iertutil.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of iertutil.dll, it's best to obtain it from its original, legitimate source. Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the iertutil.dll error.
  1. Restore iertutil.dll from the Recycle Bin. The easiest possible cause of a "missing" iertutil.dll file is that you've mistakenly deleted it. If you suspect that you've accidentally deleted iertutil.dll but you've already emptied the Recycle Bin, you may be able to recover iertutil.dll with a free file recovery program.
    Important: Recovering a deleted copy of iertutil.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
Feb 10, 2014 | Gateway Computers & Internet
Webcam wil not come up
Unfortunately this is a very confusing error, and one that does not really have a simple to write out answer. libiomp5.dll is a newer way of Intel accessing webcams, while libguide_40.dll is the old way of doing it. For some reason there is already a program using the older version of the file when your webcam program attempts to initiate the newer method. What program are you trying to use?
Nov 21, 2013 | Dell Studio 17 (1749) Laptop black -...
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
I am havng an error message powerprof.dll model# CQ60
http://www.fix-all-dll-errors.com/powerprof.dll/
Here is the solution for your problem.
Visit the link and click the button"Fix dll errors now" and your problem will be solved.
Feb 15, 2011 | Compaq Presario CQ60-220US PC Laptop
My of has a run dll issue and won't open any programs nn short cut no start menu how do I install missing ?
Option 1:
There are 3 step to repair run dll error
I think your computer is already very dangerous, and you should fix it immediately. I had the same problem with you, it bother me for a long time. I have searched many ways online and found that the following method is the best, my friend had run dll error too, he also quickly fix run dll error with the following method. I think you should try it, I hope it can help you:
1: Download a run dll error repair tool,install this error repair tool.
2: Open run dll error repair tool and scan you computer for free
3: Then click the Repair All Button again and your done! It is very easy to repair run dll error.
Here are the url of run dll error repair tool:http://www.repair-dll.com/
Option 2:
Run MSCONFIG at the run prompt. Check all the tabs (especially the Startup tab) for that file and uncheck it.
XP does have several files that it reads at startup (including AutoExec.bat and Confiog.sys for compatibility) and these can ALL be accessed from MSCONFIG.
You can also boot u io Safe Mode and run Malwarebytes if you have problems here.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 13, 2011 | Compaq Presario CQ60-220US PC Laptop
I've been getting an error message: sysenv.dll missing
Hi friends,
"The file sysutil.dll is missing."
"Cannot start Metamail. A required component is missing: sysutil.dll. Please install the application again."
sysutil.dll error notifications may appear while using or installing certain programs, when Windows startup or even shutdown. sysutil.dll errors are caused by situations that lead to the removal or corruption of the sysutil.dll. In some cases, those errors could indicate mostly a registry problem, a virus or malware issue.
to Fix Sysutil.dll Errors
The sysutil.dll error message could apply to any program or system that might utilize the file on any of Microsofts operating systems including Windows XP, Windows 7, Windows Vista, and Windows 2000.
You can fix a sysutil.dll error and there are many ways to do it. A registry cleaner program can help by removing invalid sysutil.dll registry entries that might be causing the DLL error. The below utility is without a doubt the best one out there at the moment.
> Click Here http://filehippo.com/download_ccleaner/
Let me know if any further clarification is required. Hope it will help! Dont forget to rate the solution!!
Dec 21, 2010 | Acer Aspire 5500 5570-2609 Laptop
Cannot access Email accounts from Internet Explorer. Get HTTPS: Error 12169. I can access Email accounts with Firefox. Also, uninstalled IE8 and went back to IE7 but that didn't help. Downloaded new...
Basically I found an article at Microsoft's site entitled "How to troubleshoot situations where you cannot complete MSN sign-up or connect to SSL secured (128-Bit) Web sites by using Internet Explorer in Windows XP"
To make a very long story short ... all you have to do is re-register the following .dll files:
Softpub.dll
Wintrust.dll
Initpki.dll
Dssenh.dll
Rsaenh.dll
Gpkcsp.dll
Sccbase.dll
Slbcsp.dll
Cryptdlg.dll
To re-register these files, follow these steps:
1. Click Start, and then click Run.
2. In the Open box, type one of the following commands, and then click OK (copy and paste is your best friend):
regsvr32 softpub.dll
regsvr32 wintrust.dll
regsvr32 initpki.dll
regsvr32 dssenh.dll
regsvr32 rsaenh.dll
regsvr32 gpkcsp.dll
regsvr32 sccbase.dll
regsvr32 slbcsp.dll
regsvr32 cryptdlg.dll
4. Click OK when you receive the message that says DllRegisterServer in FileName succeeded.
5. Repeat for each command line listed above
Mar 04, 2010 | Toshiba Satellite A35-S1592 Notebook
PowerCinema for Toshiba error message
Here we go, just paste this site in your browser and download the dll. This should correct your problem:
http://www.dll-files.com/dllindex/dll-files.shtml?msvcr71
http://www.instant-registry-fixes.org/how-to-fix-msvcr71dll-errors/
http://www.driverskit.com/dll/msvcr71.dll/2373.html
Mar 07, 2009 | Computers & Internet
Error message
"Access violation at address 10001187 in module 'servicecontrol.dll' Write of address 004054E9."
May 29, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
77 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
