Question about Zebra Z4Mplus Label Printer
Printer asks me for an archive I don't have
Hi, everybody.
I just connected my printer to the computer and I reached to a dialog box where I am suposed to write the access route for archive BAS4MZ2.dat, as I didn't know it I just made a search on the CD for this document but the result states there is no BAS4MZ2.dat archive on the CD. What am I supposed to do?
  • 53 Answers
Download the current zebra driver- zdesigner from the website zebra.com click drivers and downloads then enter your model. you have something going wrong with the current driver you have and will have better luck with the current one.
Posted on Jul 07, 2009
My printer will not print.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 21, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Tip
How to Configure a Wireless Printer Wireless printers typically come with a...
Wireless printers typically come with a transmitter that a laptop, with a wireless adapter, can connect to and print from any location in a home. In order to configure a wireless printer you will need to install the drivers and software from the installation CD that came with the printer. You will be able to run the configuration for the printer driver, for the laptop, at the end of the software installation.
  1. Insert the installation disc for your wireless printer into the drive on your laptop computer.
  2. Wait for the Installation Wizard to appear.
  3. Click the "Next" button to continue and go through each screen to install the software for the printer.
  4. Select the option to "Configure printer driver now" on the last screen of the Installation Wizard.
  5. Click the "OK" button when the Information dialog box appears.
  6. Select the printer port for your printer when the Printer Port Setup dialog box appears.
  7. Click the "OK" button when the "addport" dialog box appears.
  8. Click the "Next" button to continue.
  9. Select your wireless printer from the list of installed printers when the Add Printer Wizard window appears.
  10. Click the "Next" button to continue.
  11. Click the "Connect" button when the Configure Printer Port dialog box appears.
  12. Wait for a connection to be made with the wireless printer and then click the "Finish" button to exit the Add Printer Wizard dialog box.
  13. Repeat this process on each computer that you want to connect to the wireless printer.
on Apr 02, 2010 | Computers & Internet
Am having problem installing my hp laserjet6p printer
just check out the instructions its for both inkjet and laser printers. When installing a new printer with the Add Printer Wizard, you can choose between adding a local printer (one that's directly cabled to your computer through one of the ports) or a network printer (a printer that's connected to your network with an Ethernet connection, just as your computer is connected to the LAN).
To install a new local printer with the Add Printer Wizard, follow these steps:
1. Click the Start button on the Windows taskbar and then click Control Panel on the right side of the Start menu.
2. Click the Printers and Other Hardware hyperlink if the Control Panel window is in Category View.
Otherwise, double-click the Printers and Faxes icon if the Control Panel window is in Classic View.
3. Click the Add a Printer hyperlink in the Printers and Other Hardware window to start the Add Printer Wizard and then click the Next button, or press Enter to advance to the Local Printer or Printer Connection dialog box.
4. Make sure that the Add Printer Wizard selects the Local Printer radio button, and the Automatically Detect and Install my Plug and Play Printer check box beneath this radio button before you click the Next button.
5. If the wizard is unable to detect your printer in the New Printer Detection dialog box, click Next to install the printer manually.
6. Select the port for the printer to use in the Use the Following Port drop-down list box in the Select a Printer Port dialog box and then click the Next button.
7. Click the manufacturer and the model of the printer in the Manufacturers and Printers list boxes, respectively, of the Install Printer Software dialog box.
If you have a disk with the software for the printer, put it into your floppy or CD-ROM drive and then click the Have Disk button: Select the drive that contains this disk in the Copy Manufacturer's Files drop-down list box and then click OK.
8. Click the Next button to advance to the Name Your Printer dialog box.
If you want, edit the name for the printer in the Printer Name text box. If you want to make the printer that you're installing the default printer that is automatically used whenever you print from Windows or from within a Windows program, leave the Yes radio button selected beneath the heading, Do you want your Windows-based programs to use this printer as the default printer?
9. Click the Next button to advance to the Printer Sharing dialog box.
If you want to share this printer with other users on the network, click the Share Name radio button and then, if you want, edit the share name (this is the name that the other users on the network see when they go to select this printer for printing their documents) that the wizard gives the printer in the Share Name text box.
10. To print a test page from your newly installed printer, click the Yes radio button selected beneath the heading, Would you like to print a test page? in the Print Test Page dialog box.
11. Click the Next button to advance to the Completing the Add Printer Wizard dialog box, where you can review the settings for your new printer before you click the Finish button or press Enter to finish installing the new printer.
To use the Add Printer Wizard to install a printer that's available through your Local Area Network, you follow just slightly different steps:
2. Click the Printers and Other Hardware hyperlink if the Control Panel window is in Category View. Otherwise, double-click the Printers and Faxes icon if the Control Panel window is in Classic View.
3. Click the Add a Printer hyperlink in the Printers and Other Hardware window to start the Add Printer Wizard and then click the Next button or press Enter to advance to the Local or Network Printer dialog box.
4. Click the A Network Printer or a Printer Attached to Another Computer radio button in the Local or Network Printer dialog box and then click the Next button or press Enter to the Specify a Printer dialog box.
5. If you know the name of the network printer, click the Connect to This Printer (or to Browse for a Printer, Select this Option and click Next) radio button and then enter the network path in the Name text box.
If your network printer is on a network that uses an Internet address and you know this URL address, click the Connect to a Printer on the Internet or on a Home or Office Network radio button and then enter the address in the URL text box. If you know neither of these pieces of information, leave the Browse for a Printer radio button selected and then click Next to advance to the Browse for Printer dialog box.
6. In the Browse for Printer dialog box, locate the printer in the Shared Printers list box by clicking the network icons until you expand the outline sufficiently to display the printer icon.
When you click the printer icon in this outline, the wizard adds the path to the Printer text box above.
7. Click the Next button to advance the Default Printer dialog box.
8. Click the Next button to advance to the Completing the Add Printer Wizard dialog box, where you can review the settings for your new printer before you click the Finish button or press Enter to finish installing the new printer.
After you add a printer to your computer, you can start using it when printing with programs such as Word 2002 and Excel 2002, or when printing from Windows itself.
To switch to a new printer that you haven't designated as the default printer in programs such as Word and Excel, you need to open the Print dialog box (choose File-->Print) and then select the printer name in the Name drop-down list box.
Feb 02, 2009 | HP LaserJet 6p Printer
Epson stylus c46
Go here: http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20C46-_E
You can get the user guide as well as a setup guide.  If this helps please rate my solution.  Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/larry_1fe25e09c54eece2
Dec 11, 2008 | Epson Stylus C46 InkJet Printer
I have a H-P Compaq Presario A900 Notebook PC and it came with a Canon Pixma MX310 all in one printer. It has windows vista 2007 on it (computer) and one of the instructions says to open the vista program...
To install the printer do this:
Nov 23, 2008 | Office Equipment & Supplies
I need help installing this printer to my computer no disc
You can download the driver here:
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 15, 2008 | Epson Stylus C66 InkJet Photo Printer
Dont know how to install my printer to my computer
hi!!!
here the things you gonna do
Sep 19, 2008 | Computers & Internet
To use two computers with hp psc 2110v printer
It would depend on whether the computers are in the same room or not, If they are in the same room then all you have to do is use a USB Switch. hook the printer to it then connect both computers to the switch, just change the computer thats used on the switch as and when needed. If you are wanting to use 2 computers over a network then its an entirely different solution.
Step One:
First make sure your machine is set up for File and Print Sharing. Secondly, check to see if the printer you wish to use is set up for sharing also. If not, follow these directions.
1. Right click the printer to be shared.
2. Select Sharing on the menu
3. Name the Printer to be shared.
4. Click OK. A hand should appear under your printer.
Step Two:
Open your Printer Folder. Start/Settings/Printers.
Select Add Printer.
Step Three:
An Add Printer Wizard dialog box will appear, click on Next at the bottom.
Step Four:
• The dialog box will ask how the printer is attached to your computer.
• Select Network printer by clicking in the radio button.
• Click on Next at the bottom of the box.
Step Five:
The box will ask you for the path to the printer. Select browse. Your network neighborhood will open.
Find the name of the computer to which the printer is hooked up. Click on the name of the computer. Then click on the the printer name to highlight it . Click OK and Next
Step Six:
You can name the printer on this dialog box. Usually, the printer brand and room number is sufficient. The box will ask you if you want to print from a DOS program. The default is No. Click on Next at the bottom of the box.
Step Seven:
If you have already installed the printer before, it will ask if you want to keep the same drivers. If your machine is having problems printing from this printer, which is why you are reinstalling, then select Replace existing driver. Otherwise, you can select Keep existing driver.
Step Eight:
The dialog box asks if you wish to print a test page. Select Yes, and Finish.
Step Nine:
Another box will come up and ask if the page successfully printed. If so, select yes.
You will see your new printer in your Printer Folder with a line underneath it indicating that this is a network printer.
Sep 13, 2008 | Office Equipment & Supplies
Unable to connect my FujiXerox DocuPrint 203A to my Pentium Computer. Have CD (English) but cannot load as disc drawer broken and need to be able to load by on-line instructions. However cannot locate. Can...
Click on this sentence to download a zip file.
It will start a download process. Choose uncompress, and then save it to your desktop. Inside the folder within are the files to install your printer again.
Shut down your computer and when off turn off the printer too.
Restart the computer and when you have reached and logged into your desktop turn your printer back on. Windows has or will say new hardware found do you want to install this hardware or words to this effect, choose yes and you want to no or shortly tell the dialog box where to look for the files, you will see a choice circle and a browse button. You want to browse to your desktop and open the file that has the downloaded files. Once the dialog box has this location open click on OK. The installation should proceed and complete by offering to print a test page, choose yes.
If you do not get the new hardware found, go to start menu, settings, Control Panel, Printers or Start Menu, Printers and Faxes choose add new printer and when asked what, browse to the desktop and the folder containing the files you just downloaded and the install process will begin.
That should do it. Sorry these are not recipe driven instructions but you and perhaps a friend can use them to get you back in business.
Let me know how you make out or get stuck. Use the comment box below to reach me. I'll be notified by email and get it and reply at my earliest chance.
Please don't forget to rate and thanks for using FixYa.com
Regards,
Worldvet
Sep 07, 2008 | Fuji Office Equipment & Supplies
Lexmark 3100 printer
hi
U first install the printer software which is given by the printers and install it. after that u connect the usb port it will automatically ask you whether u connect and let u install the driver for it
Feb 21, 2008 | Office Equipment & Supplies
Zebra Z4Mplus Label Printer Logo
390 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
