Yamaha 2004 Kodiak 400 Auto 4x4 Logo
G
George dibattiste Posted on Sep 01, 2014
How do I fix My kodiak 400 that will not shift into reverse or park
The shift lever will not move to the reverse or park position. It goes into high and lie ok
Jrew Lafont
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 9 Answers
  • Posted on Sep 02, 2014
Jrew Lafont
Contributor
Level 1:
New Friend:
Welcome Back:
Problem Solver:
Answers
9
Questions
Helped
9811
Points
10
As soon as your bike begins to high idle it will not fall into gear you probably will need to set your linkage on your shifte
400 kodiak only starts manually reverse lightwont go off unless head lights are on
short in wiring or loose wire at a connector. check and repair any found
2003 Yamaha Kodiak 400 back fires and kills. This happens on full throttle. What could could be the issue?
The high speed jet isn't rich enough or the carb passages needs to be cleaned. You can move the clip down one spot on the needle so it gets more gas, this will also give you more power at the top end.
2001 Yamaha kodiak 400 4/4 spark comes and goes
look for loose wires and check the resistance of the plug cap
2answers
What is the problem my ATV polaris 400 is stuck in reverse
you are going to have to adjust the linkage from shifter to tyran they all stretch over time had it happen many times on the Polaris.
Feb 21, 2015 • Polaris ATV
What is the cause for my kodiak 400 shift lever not to move into reverse or park
Check to see if one of the shifter rods behind the side pannel are bent.this usually happens due to lack of lube end people try to force it into gear.
Top Yamaha ATVs Experts
ADMIN Andrew
ADMIN Andrew
Arnie Burke
Arnie Burke
john h
Are you a Yamaha ATV Expert? Answer questions, earn points and help others
