Cell Phones Logo
Posted on Jul 02, 2009
Know wich cloned cell phone can buy for the sim of Claro P.R.
Hi!
I want to know if there any cloned cell phone with touch screen and java suport who work with the sim of CLARO PR. Because i have interest in buy I9+ or I68+ but some person told me that´s model didn´t work with that carrier.
thanks for Help!!
China clone iphone a1332 sd card games application not found
The china iphone clones are not actually iPhones - they are usually android phones with a skin that makes them look like apple products. The clue is the fact you have Java installed, which is used my Android and not iOS (Apple's iPhone OS). Your phone will never work as a real iPhone.
Hi i purchased a bb 8330 RIM cdma from us and how can i use it in India with a suitABLE NETWORK HERE
You only need blackberry curve 8330 unlock code for your original sim network provider. Example : if your original blackberry network card using claro, then you just need blackberry unlock code for claro network, The easy way to get that unlock code is buying from third party sites and you just need to wait a couple minutes then unlock code will be arrived in your email complete with details instruction how to insert that unlock code in your blackberry phone.
95helpful
11answers
Activate gprs on sciphone I9+++ & download java games
hi um can anyone tell me to install java games.because every time i open a game it says please install java game.how do i do that
1helpful
I HAVE A CLARO ACCOUNT BUT CANNOT GET INTERNET
I found these internet settings for Claro from another website:
http://forum.itechinnovations.com/index.php?tid=101
Claro's Internet Settings are:
WEB CLARO & Java Claro
homepage: http://internet2g.claropr.com
APN: internet.claropr.com
Port: 8080
username:
password:
authentication: none
Primary DNS: 0.0.0.0
Secondary DNS: 0.0.0.0
IP address:
WAP CLARO
HOME: http://wap2g.claropr.com
PROXY: 10.50.38.3
Port: 8799
APN:wap.claropr.com
MMS CLARO
Homepage: http://mmsg.claropr.com:1021/mmsc
APN: mms.claropr.com
PROXY: 10.50.38.3
Port: 8799
username:
password:
IP address:
This is how you set it up on your phone. Just substitute the settings provided with the ones above:
From: http://www.tomshardware.com/forum/49719-36-a008-ming-xing
The setup of WAP and MMS on your DUALSIM Mobile Phone is carried out in 4 stages.
• MMS Data Account Setup
• MMS Setup
• WAP Data Account Setup
• WAP Setup
Step 1 – MMS Data Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS > Select an empty Account”
2. Edit the following parameters in the account
a. Account Name = OptusMMSGPRS
b. APN = mms
c. User name = [blank]
d. Password = [blank]
e. Auth. Type = Normal
3. Exit back to MAIN SCREEN.
Step 2 – MMS Setup
1. Go to the following menu “MENU > MESSAGES > MMS > MMSSETTINGS > SERVER PROFILE > SIM 1 or 2 > Select an emptyAccount”
2. EDIT the following parameters in the account
a. Rename Profile = Optus MMS
b. Homepage = http://mmsc.optus.com.au:8002
c. Data Account = OptusMMSGPRS
d. Connection Type = WAP
Proxy Address = 061.088.190.010
e. User Name = [blank]
f. Password = [blank]
3. BACK then ACTIVATE PROFILE and exit back to the MAIN SCREEN.
4. Your Phone is ready to access WAP and MMS services.
Step 3 – WAP Data Account Setup
a. Account Name = OptusWAPGPRS
b. APN = prepaidyesoptus
Step 4 – WAP Setup
1. Go to the following menu “MENU > SERVICES > WAP >SETTINGS > EDIT PROFILE > SIM 1 or 2 > Select an empty PROFILE> EDIT PROFILE”
a. Rename Profile = Optus WAP
b. Homepage = http://networker.optus.net.au/wap/index.wml
c. Data Account = OptusWAPGPRS
Proxy Address = 202.139.083.152
Hope this helps!
WizardRepair
Jul 17, 2009 • Cell Phones
2answers
Nokia n99i tv phone
hi adeola, you need a .jar file. go to www.getjar.com choose your device (there's no n99i-unless some chinese clone). you can check your device id on the white sticker under battery.
rate me if helped,thanx.
6helpful
I9/168 + sci phone vodafone & vigin work on sim1 slot only ?
Make sure the sim cards are inseted properly, SIM 2 wich is the bottom slot the gold chip has to fase up, (yoe see it when you insert it) sim 1 wich is the top, the gold chip faces away from you, so basically with both sims in the chips face each other. also make sure both sim slots are turned on in your phone settings.Settings => Dual SIM settings => Choose the proper SIM setup => OK in this case you would select Dual SIM open then OK.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact [email protected] Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
2answers
I have Iphone clone and I get ''no service'' when my AT+T sim card
without knowing which version you have it would be hard to help you. you need to find out and go to
i9forum.co.uk they can assist you.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
