Question about Hunter (25417) Ceiling Fan
Remote control installation
Purchased 27314 west indies collection ceiling fan and a separate hunter remote control model 29157.
I would be grateful for clearer instructions on the wiring connections of the remote control receiver when it is placed in the canopy.
There are three wires (w, b, w/b) entering canopy from below and five wires on the remote receiver.
The five wires are labelled but I have no idea how they should connect to the three (w,b,w/b) wires.
  • 351 Answers
SOURCE: The canopy doesn't seeem to fit flush up against
You just need to wrap it and tuck it .. You might need to cut some of the fan wires shorter so there is not so much bulk under the canopy cover. The fans are shipped with enough wire leads to be able to use a down rod, They can be cut shorter when the fan is being installed.
Posted on May 06, 2010
  • 14 Answers
SOURCE: where does while lead from ceiling connect? capacitor has five leads, 2 gry, 1rd, 1 grn 1br, (grn gry br to switch) switch has black lead to ceiling lead.
White is the common, or neutral. There should be a white wire to connect it to.
Posted on May 24, 2009
SOURCE: Hunter ceiling fan. Lights and fans turn on and
Obviously you have 2 (two) hunter fans with remote, so one of the fan needs to have frequency changed : on the base fan you will find (white rectangular )receiver that has 8 (eight small) switches, the same switches you would find in the remote control, slide 1 switch up ( on the remote and the receiver). Make sure same number ok (these 8 switches has #'s 1,2,3,4,5,6,7,8) then reinstal your fan back the way it was. you'll be fine. good luck
Posted on Jul 27, 2009
SOURCE: Im installing a hunter remote control receiver in
The red wire in the ceiling is probably used in a shared neutral circuit and not needed for the fan. If it's not capped off already, it should be.
Just use black, white and ground from the ceiling.
Posted on Aug 21, 2009
SOURCE: I have a Hunter Fan purchased in 2003. It has the
Called Tech Support
Posted on Oct 08, 2009
Minka Aire model f603 reverse switch?
Not sure what model of fan or manufacture you have. Says Hunter 52" & Minka aire F603. If it's the Minka , Then push the button on the lower part of the remote (6 o'clock). If that doesn't work then you might need a new receiver.
Jul 23, 2014 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan model 23530-300
the roll was rusted maybe .you can take apart it for checking .
ceiling light
May 01, 2012 | Hunter Ceiling Fan Remote Receiver...
Need the manual for our ceiling fan, Hunter, Park
i have to fans close to each other i would like to change the code on the remote
Apr 24, 2010 | Hunter Ceiling Fan Light Remote Control
Hunter ceiling fan. Lights and fans turn on and off by themselves.Both fans are on the same wall switch and are operated by separate remotes.
I just installed a 2nd hunter fan model 23811 that also seems to be controlled by grimlins. If the power is left on, the light and fan randomly turn on and off. And no, it is not due to fans being on the same frequency. It appears to be an issue with the control module. I'm contacting Hunter.
Jul 26, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Apr 01, 2009 | Hunter 52" Ceiling Fan With Light And...
Ceiling fan
hi you have a problem with your fan do you have the remot book how to operate the fan remote we lost the booklet for the instruction maybe you can send me a copy of your booklet instruction for the fan is your fan is from the compagny home collection and the brend or model tampa thank you
Nov 24, 2007 | Hunter Ceiling Fan Control Switch
Hunter (25417) Ceiling Fan Logo
131 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
