Question about Philips Magnavox 9P6034C 60" Rear Projection Television
When connecting my computer on my MAgnavox monitor/Phillips Television the Screen shows in Black and Red only
I connected my computer to the Monitors of Phillips products the scree shown in black and red only. No other colors
  • 137 Answers
One of your connector wires or pins are damage.
Posted on Jun 29, 2008
How do I repair my 19in LCD monitor, it receives video signal, but goes black screen?
Connect the "bad" monitor to the VGA-out port on a notebook/laptop computer, to see if it works normally when connected. If not, then the monitor is "dead".
If it works fine, check the "screen-resolution" of the computer's video-card, to see if the values exceed the capability of the monitor.
May 05, 2015 | Computers & Internet
Screen auto changes black when conecting
try resetting the brightness control and checking to make sure that the printer cable is securely connected to the computer and the monitor. Your monitor cable may also have a crack or broken wire in it or the connection itself may have come loose.
Try plugging in an external (borrow a friends if necessary) monitor just to check and make sure that the connection on your computer is good and that the problem is not in the wiring of your LCD screen. There are several other things that may help you, let me know if you are still having problems.
Feb 08, 2010 | BenQ FP71E 17" LCD Monitor
Connection?
check the videocard. remove it and place it again if no improvement try to connect monitor to another system. If no color, replace monitor.
Nov 03, 2009 | Gateway FPD1975W 19" LCD Monitor
Power on - blank (black) screen
Disconnect the monitor signal cable from PC and switch on your monitor. It should show some logo with Red, Green and Blue colors with a message similar to "No signal". If so, your monitor is working fine. Sometimes if the brightness and contrast is set to zero using controls present in the monitor, it will not show up anything. check wheather somebody set your monitor brightness and contrast to zero. If so incease them. As a last try connect to different PC and check before approaching a service center. I hope this will help you out. :)
Aug 21, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor shows screen then goes black
It is the Monitor Cable connected to the CPU cabinet is faulty. Please check out the cable and its pin firmly.
Try to find the fault, may be the cable broken or tear up.
Let me know if further diagnose required.
Have a nice day.
Ellin
Oct 14, 2008 | Hyundai ImageQuest Q15 15.1" Flat Panel...
Tech Help
If you have AUX A / V inputs on your Magnavox television, yes it should work.
KDonald
Jun 02, 2008 | Samtron 76df 17" CRT Monitor
Phillips 170b monitor not working
Exactly the same problem here. Phillips 170B Monitor about two years old. Lights up for no more than 2 seconds then goes blank. Switch on/off and exactly the same thing. I suspect than the screen goes really dim rather than switching off because sometimes I can see the screen image very faintly.
Dec 31, 2007 | Computers & Internet
Monitor only stays on for 3 seconds
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Aug 17, 2007 | Philips 170S4FB 17" LCD Monitor
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
