Question about Craftsman 25cc Gas Line Trimmer
What size are the feul lines - Craftsman 25cc Gas Line Trimmer
  • 1,041 Answers
The best way to get the correct fuel lines is to take a piece of the old line and match it up with the new. You may have two different sizes, so make sure to grab a piece from both.
Your local auto parts store may carry them. If not, any outdoor power & equipment type of store will have them.
Jim
Posted on Jul 03, 2009
  • Jim Parker
    Jim Parker Jul 03, 2009
    Thanks for the rating!
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
Whitch feul pipe at engine is feul return
The fuel return line is typically the smaller line.
Dec 03, 2017 | Cars & Trucks
Feul lines
Its possible that you have the fuel lines reversed.
Jul 17, 2012 | Garden
My fiat uno 1993 model,Cuts out and struggles to get petrol through,I have replaced the feul filter.
Just check,
  • fuel pipe
  • fuel pump ,fuses, wiring
  • if mpfi engine, check the injectors.
  • spray some fuel line cleaners into fuel line, pcv, air filter
  • pls vote!!
Sep 24, 2011 | Fiat 500 Cars & Trucks
I replace the fuel pump in my 1990 full size bronco and now I cannot get it to crank. The reset button is depress, the filter is new, and new feul is in the tank. Pleas let me know what else I need to...
Your ford should have a schrader valve in the fuel rail for testing fuel pressure. You shouldn't need to remove a fuel line. On the left inner fender there are two, maybe three relays, usually encased insome type of enclosure. The relay with the green plug is the fuel pump relay, the relay with the brown plug is the EEC relay. Unplug both of these relays and inspect for corrosion, broken pins, and corrosion. A problem with either relay will cause the fuel pump not to run as the EEC relay controls the fuel pump relay. Corrosion at these connections has been very common at my shop.
Sep 05, 2011 | 1990 Ford F150
Saturn SC2 - 2001 1.9 DOHC 5-speed man. Runs fine, starts cold. After running for a half hour or so if you stop the engine....you sometimes need to wait up to five minutes before it will start again. ...
There could be a few reasons for that happening....It is most likely a FEUL problem. Is it feul injection or carburettor?? If it is a carburretor, then there could be dirt in the jets. You could also have an inline filter that is blocked & not enough feul is getting through to the carb. Another thing that could be causing the car not to start after being running awhile is if the feul line is too close to the engine and is getting too much heat, causing the feul to "bubble" and faporise in the line, untill it cools down. Another cause could be that the float level in the carb is set too low or you have a faulty needle & seat.
Hope this helps.
Feb 09, 2011 | 2005 Saturn SC2
Deisel fuel getting to injector pump. Feul also getting to pump bleeder. No feul getting to injector lines or return line even as engine is being cranked. Machine is a 530 case construction king. Tractor...
you prabably have an airlock inside the injector lines.
Disconnect two lines and crank again,this will push out the air so fuel can get to the injectors.once the fuel comes out reconnect the lines and it should start
Aug 29, 2017 | Milwaukee Tool Case Heat Gun
Changed feul pump feul filter changed computer. Van still shutdow
this could be a number of problems,check the voltage with a volt meter,not a test light at the fuel pump connection. make sure you have 12V,if so unhook the fuel supply line,turn key to ON not START, and make sure the pump will continue to flow,( obviously cqatch the fuel with a pail,or put a hose on it to pump it into a pail,don't let it leak all over the place.)if the pump continues to flow with out shutting off,your pump,filter,and electrical for your pump is ok.it could be a restriction in the return line,or the regulator may not be functioning.un hook the return line as close to engine as possible,install hose on it and route to a pail to catch fuel,with supply line hooked back up,start van and see if it works,if it keepd shutting off,you've now eliminated return line problems.check the regulator.
Oct 07, 2009 | 1996 Dodge Caravan
Having a hard time removing the fuel filter.
get a press fit tool for gas line that removes the line .Mak sure you release the pressure in the line first .which is under the hood on the feul rail looks like a valve stem on a tire .watch your eyes when releasing pressure fuel well spray out hold a rag over it .there are different size tools to release the clips on the fuel filter make sure you get the right size .you can buy the all 5 of them fairly cheap all for under $20
Feb 16, 2009 | 2000 Jeep Grand Cherokee
Craftsman 25cc Gas Line Trimmer Logo
139 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
