Check hoses for any kinks or clogs that may prevent the water from
draining. If a hose has kinks, try to straighten out the kinked hose.
If it can't be straighten sufficiently, replace the hose. If hoses are
not kinked, check for clogged hoses. This can be done by using the
screwdrivers to remove the hoses and looking for clogs or running a
water hose through the clogged hose to remove the clog. Use the rags
and bucket to clean up the water that comes out of the hoses when they
are disconnected. Once the clog is cleared, put the drain hose back
into place. The washer should drain and spin now if a clogged or kinked
hose was the problem.
Thanks.
Kevin
Problems
with a washing machine not spinning or not draining are often inter
related..
If you are having a problem with your top load
washer then check out this tip...
Washing
Machine
does not Pump or Spin
If you are having problems with your
front load washing machine then checkout this tip...
Front
Load Washing
machine not draining and or not spinning
heatman101
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
