Question about HP Pavilion ze4125 Notebook
Audio Device
The os is crystal xp. The sound is not fucntioning whilst Device Manager is also not workable. I downloaded the audio drivers and installed alright but still could not work. Please help ASAP.
  • 1,006 Answers
Re: Audio Device
Email me at and i will send one software u just open it and send screen shoot to my email and i will find right driver for you...Also frist UNINSTALL ALL DRIVER RESTART COMPUTER AND try to install driver from safe mode!
Posted on Nov 09, 2007
0 characters
3 Points
Hi i have hp pavilion dv6500 vista i changed it to windows xp and now i cant play any sound there is no sound device
When you are going from vista back to xp windows it is hard to find the supported device drivers. The only thing I can suggest is go to to see if they support xp audio driver, failing that do a google search for your make and model to see if somebody has come up with a solution.
Dec 28, 2010 | PC Laptops
I Have Problem to install audio xp to lenovo
1. Download the audio driver here. Save to your Desktop (or to any prefered folder).
2. Uninstall the audio driver thru device manager.
To go to Device Manager, click on Control Panel > System > Hardware tab > Device Manager > Expand the Sound, video and game controllers by clicking on the + symbol > Right click on your sound card > Properties > Driver > Uninstall
3. Install the downloaded driver from the Desktop (or your prefered folder).
4. Restart the computer.
May 30, 2010 | Lenovo 3000 G530 Notebook
No sound device
Hello Friend,
You need to Install Audio Driver for Your System
  • Uninstall if any driver installed Previously by Going to Device Manager on Audio Tab
  • Reboot
  • Click here to Direct Download sp35940.exe (Go to Download page Click here )
  • You are Done...Ready to Use..
OR if not Worked Above go to Following.. >For Vista Drivers Click>Audio Driver XP (32-bit) Link
>Audio Driver for Microsoft Windows XP (64-bit) Link
Hope This Helped you..Thanks for Contacting FixYa..
May 06, 2010 | HP Compaq Presario C500t Notebook
No sound after installing Windows XP
install your original sound driver. don't install buetooth. sound driver first, bluetooth causing audio failure.
Jun 02, 2009 | PC Laptops
No sound driver working on my gateway notebook pc
Did you check the Device Manager, the audio driver, has it a yellow ? against it or is it OK and enabled? If it is has the MUTE button been ticked?
If it has a yellow ? against the audio driver then the correct audio driver was not installed. Go to the Gateway Support/download page to download the correct XP driver for your model laptop's audio device and install it.
If the sound still doesn't work check Device Manager to see if the driver was installed and working.
Apr 08, 2009 | Gateway MX8711 Notebook
My system cannot playback sound
u have to reinstall your sound driver
first uninsytll your current driver form device maanager.
also remove its application in add remove pro in conrol panel.
download from here and install it.
Nov 15, 2008 | Dell Inspiron 4100 Notebook
Sound problem
Hi thr,
If u r runnin Windows XP, Go to control panel. click on system->hardware->Device Manager n check to see if the sound drivers r installed properly. If the lists shows a yellow exclamation mark on PCI DEVICE, It means u need to install microsoft universal audio articeture drivers first. u can search for it on yahoo or any other searchengine to get the link. download and install microsoft uaa drivers, Uninstall the PCI device from device manager and re-install the audio drivers. I hope it works this way. Thank u
Nov 06, 2008 | Compaq Presario 700 470024-192 Notebook
Well, probably they forgot to reinstall audio driver.
Check first that your volume is not at minimum ar audio had been muted, check from 'audio mixer' or from 'control panel/sound, speech.../adjust audio volume'
If volume and mute are ok, download driver from this website and install it again.
You need to select your model, your OS (windows version), and then audio or sound driver download.
Once you download the audio driver (chose save) run the download.
If you do it properly it will work again.
Jul 18, 2008 | HP Compaq Presario V2000 Notebook
Sound drivers
I hope you want drivers for xp ,because vista automatically install most of the drivers for the components which are attached to system by its own database from the vista dvd
Remember Installing only audio drivers will give you error .so to solve this problem first you have to download microsoft universal audio driver and then install audio drivers
Audio Drivers for xp
link 1 :microsoft universal audio
link 2 :conexant high definition audio
you can use this link for xp other download from hp website
or you can use this link for vista
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so it will be highly appreciated if you could take a minute and provide your feedback..
Thanks for using fixya support..You have a wonderful day
May 31, 2008 | Compaq Presario 700 470024-192 Notebook
HP Pavilion ze4125 Notebook Logo
Top HP PC Laptops Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a HP PC Laptop Expert? Answer questions, earn points and help others
