Question about SPL Audio Phantom DK2-1000 Car Amp
What size fuse is needed for my amp spl dk2-1000
    Problem Solver:
  • 16 Answers
2(two) 25 amp fuses!!!
Posted on Jul 03, 2009
I Have an spl audio amp 520 watt and when it turns on it automatically goes to red which is protect. what could be causing this problem
It could be 3 things. There could be a short somewhere, your ground isn't strong enough, or you accidently switched up the ground line and the power line on the amp. Since the fuses aren't blown I would say that your ground isn't strong enough.
May 01, 2011 | SPL Car Audio & Video
I have an SPL Z1X 3000D Mono (3000W) amp that I just got so I could maximize my Sub's output. But My Kenwood 800W amp has better sound quality and is much louder. I don't know why
because a kenwood amp is true power and has better pertection built in it.the spl is a cheaper brand of equipment.just because it says 3000 whats doesnt mean it is,the spl is about 150 - 200 brand new,that should tell you why
Dec 12, 2010 | SPL Dynamics Z1X-3000D Car Audio Amplifier
I have spl crm520-2 amp and the light does not go on
power supply is bad spl is not a good compane i would replace the amp
Jul 06, 2010 | Car Audio & Video
Why do the fuses in my amp keep blowing
You may not have they proper size wire to the amplifier. Most amps now recommend 4 ga. Also make sure your wiring to the speakers are at the proper Ohm load.
Dec 05, 2009 | SPL Dynamics XL2-820 SPL Car Audio...
I have an spl gorilla series 1250watt amp that blows fuses
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL BLOWS THE FUSE, THEN IT WILL NEED TO BE SERVICED. IF IT BLOWS THE FUSE BEFORE TURNING IT ON, THEN YOUR PROBLEM IS IN THE POWER SUPPLY SECTION. IF IT BLOWS THE FUSE AFTER ATTEMPTING TO TURN IT ON, THEN YOUR PROBLEM IS PROBABLY IN THE OUTPUT SECTION. ALSO KEEP IN MIND THAT THE P1'S ARE REALLY NOT RATED FOR THAT MUCH POWER AND YOU MAY HAVE DAMAGED THE VOICECOILS. BEFORE REINSTALLING THE AMPLIFIER, MAKE SURE TO CHECK THE SPEAKERS FOR SHORTED VOICECOILS OR YOU WILL POSSIBLY DAMAGE THE AMPLIFIER AGAIN. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 19, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
The fuse blew on my spl 1920watt amp and now the protect light wont go off and it wont do anything
Did you put a new fuse in it? If you didn't then put a new fuse that is rated at what the amp calls for. If you have and the light stays on, then odds are there is a broken wire inside and the amp needs repairing or replacing.
Jul 12, 2009 | SPL Audio Car Audio & Video
What size fuses do i need
YOU CAN USUALLY GO WITH THE GREEN ONE 30.
May 02, 2009 | SPL Dynamics XL2-820 SPL Car Audio...
Fuse Size??????
The fuse size shouldn't matter with the low voltage problem you are describing..Fuse size should be 10A fast blow(AGC). Verify that you have a good 12v power source feeding your unit...your dimming problem is voltage related.
Mar 29, 2009 | SPL Dynamics SDVD7400R Car DVD Player
550x2 subs....SPL z2x-820 Amp
The 230 watt amp is a little small for your subs. They'll work, but if you are looking for max SPL, you won't get it. To push those Audiobahn's to their potential pavement shaking max, I would recommend an amp in the range of 500-600 rms (2-channel bridged) or 1000 watts rms monoblock.
Hope this helps.
Mar 28, 2009 | SPL Dynamics Z2X-820 Car Audio Amplifier
SPL Audio Phantom DK2-1000 Car Amp Logo
170 people viewed this question
Top SPL Audio Car Audio & Video Experts
xxxxxx xxx
Are you a SPL Audio Car Audio and Video Expert? Answer questions, earn points and help others
