sound like you have a parasitic drain on the battery,needs to be tested with an amp draw meter with engine off, something is drawing amperage from the battery
SOURCE: cluch wont bleed
bad slave cylinder/hydrolic?-bad pressure plate/throughout bearing
replace them it should fix it.ive been there before!!!!!!!!!!
SOURCE: cluch does not bite until
This happens with heavy duty clutches, when there is air in the clutch hydraulic lines. Firstly bleed the clutch lines and see what happens.
