Need a replacement remote control is there a universal that will work the television
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
SOURCE: ilo tv/universal remote codes
Here are some to try, mine was 0189, but there are many to try. 0051 0189 0053 0198 1070 1024 1023. I think some listed codes for Emerson work as well.
SOURCE: Digimate TV DGL20 REMOTE CONTROL
Use just about any remote and use the code for a Protron TV.
1) 0178
2) 0466
3) 0052
4) 0003
First one worked for my digimate 20"
SOURCE: Remote Sensor
I heard that LG TVs have a problem with the TV not responding to the remote control (there is nothing wrong with the remote control). Hopefully your TV is still under the 2 year warranty. Go to LGService.com and report the problem. They told me that it's a common problem. They need to order the part and let me know when it comes in. (my TV is a LG 50PC1DRA)
The Akai TV might have LG guts inside.
SOURCE: need codes for universal remote for ilo television
I dont know which remote you are using but you might want to try these 2 codes... 0171 and 1990
These codes are also mentioned depending on which universal remote being used ...
10180 10171 10171 10179
Good Luck.
SOURCE: I need a universal remote
I can confirm that the 0441 code does indeed work for the Xbox 360 Universal Remote. I just programmed it and it works perfectly. Thanks to the person that first posted that code!
