Question about HP Compaq Presario SR2013WM (RE468AA#ABA) PC Desktop
Boot disk failure pops up when computer comes on an will not allow the computer to go any further.
  • 22 Answers
There are several possibilities:
1) your hard drive crashed and you can no longer boot off it.
2) You have a floppy or other similar removable drive loaded and the system is trying to boot off removable media which is not bootable.
3) Your boot record got damaged somehow by some software or malware writing to the boot sector of the drive, but your data is still there.
If the problem is #1, you can try a repair install of your operating system and see if that works. If the hard drive itself is damaged, this won't help.
If the problem is #2, I'd just make sure you have removed all removable media before trying to boot.
For problem #3, the way to test this out is to remove the hard drive (with the system powered off, making sure you have discharged all static electricity) and place it in another machine as a "slave" drive and see if you can access the data on that drive. If you can, there's a possibility that you can repair the boot sector. However, this is not really a job for amateurs as there's a very good possibility you can permanently wipe the data on this drive or on the main boot drive of the computer you're using to test with.
Posted on Jul 02, 2009
No bootable device detected
If you strike F1, the system retries as said in the comment. That does'nt solve anything. Rather strike F2 which allows to enter the setup menus of your computer.
In this area you should understand what you are doing. Any update of setupdata may prevent further restart. At least take note of values and changes. You exit setup via a question "update Y/N". Then the computer restarts.
Anyway, in the setup menu you may inspect the devices and see if you the system identifies the disk. If not it may come from a bad connection of hard disk (sata pins, ...) or from low level disk information (format information).
With setup menu you may get in the boot order menu, that allows for the selection of an alternate boot media. You may boot on an installation media, ( install DVD generally, like originall windows install DVD) in order to understand and repair the situation, or from a rescue system like UBCD. You may also try Ubuntu from the CD without installing, just to verify if you may see the disk in the configuration.
Regards
Jul 09, 2014 | HP Computers & Internet
Toshiba laptop restarting
The loop on your Toshiba Satellite laptop refers to the computer not booting properly.
During the loop, the computer will try to boot the Windows operating system and keep restarting over and over again.
This is not a hardware issue with your Toshiba Satellite A106.
The issue resides in the startup files on your computer's hard drive.
You can fix this by running a repair tool that comes with your Windows operating system.
This repair tool will fix your startup disk and allow you to get your computer back up and running.
Insert your Windows 7 installation disc into your computer's optical drive.
Start your computer and wait for it to boot from the install disc.
Choose your language from the menu and then click the "Next" button.
Click "Repair your computer" from the menu.
Choose the operating system you are using and then click the "Next" button.
Click on the "Disable Automatic Restart On System Failure" button to disable the startup loop.
Click the "Startup Repair" tool from the menu and wait for the computer to fix your startup disk.
Wait for the computer to finish repairing your startup disk and then allow it to restart automatically.
Wait for the computer to boot correctly to your login screen.
Hope this helps
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
Oct 23, 2012 | Toshiba Satellite M35X-S311 Notebook
I think I went to a virus riddled website. My computer shut down. Now when I restart it, it comes on for a few seconds and a blue screen pops up and tells me Windows is shutting down to prevent damage. How...
avg makes a down-loadable boot disk download this and burn to disk select your dvd/cd as your first boot device then and follow on screen prompts. the virus as corrupted the MBR (master boot record ) that may have to be repaired after the virus is removed
Oct 21, 2010 | Computers & Internet
What do i do for a disk boot failure. When I hit alt/del/ ctrl. the computer stills comes on but I feel I need to fix the disk boot failure what can I do
I suspect the disk has some error
- Click My Computer -> Right Click Drive C: -> Select Properties -> Click on tools -> Then Select Scan Computer ... -> Click ok
- Restart your computer and allow it to run the Scan disk Utility
Oct 07, 2010 | Computers & Internet
Have a gateway Mt3708 it started turning off on its own now I have no screen. I had gotten message reading as follows: YUKON Pxe V4.17.8.1 (alpa) (20060116) (C) copyright 2003-2006 Marvell (R) all rights...
when the logo comes on, press the "tab" key. It should turn the logo off and show you what the computer is doing. This may help:
THIS IS FOR HP AND COMPAQ USERS (it might help others as well)
i had the same problem with my compaq preasrio v6000.
ALL U HAVE TO DO IS
1- START UP UP UR COMPUTER AND PRESS F10
2-GO TO DIAGNOSTICS
3-RUN A HARD DISK TEST
IF IT PASSES THEN YOU JUST NEED TO RE-INSTALL TO YOUR OPERATING SYSTEM
IF NOT YOU WILL HAVE TO CHANGE YOUR HARD DISK.
Or try this:
Go into the BIOS.. Go into the BOOT options.. and hit Shift+1 to disable the Realtek boot option.. pop in the disk you want to boot from.. and make sure you set your boot options to CD-Rom and then HDD.. and just wait.. be patient.. and the blue screen (for booting) will show up! :)
Mar 15, 2010 | Computers & Internet
My siste in laws Dell laptop quit after her daughter had used it, neither know what happened but the computer powers on and then a message like, error disc failure or disc read failure something like that...
Hi Debbie!
It sounds like you dell trying to boot up from a disk.
Get in the bios and change the boot seqvence from cd to hdd (harddisk)
Before that, check so the cdrom is empry, so the girl dident forget a disk or something in the cg-sledge.
If the cd-sledge is empty then the bios change will solve our problem.
Good luck
Nic
If you need further help, just let me know
Mar 27, 2009 | Envision EN 9110 19" Flat Panel LCD...
I try to boot my computer from a windows 98 disc, but it won't lo
Hi matthewbugbe,
I think what that means is it does not recognize your hard drive. If you are trying to install Windows 98 you should format your drive first.
Mar 08, 2009 | Microsoft Windows 2000 for PC
"Disc Boot Failure" upon powering up the compaq
your harddisk is not detected.
open your cpu case.
then reattch the power code and datacode to hard disk.
Nov 03, 2008 | Compaq Presario S6300NX PC Desktop
Computer won't boot
check if you have floppy disk or cd-rom disk inserted, the bios may have look for the operating systems on this drive. If there's a disk on this drive, remove them and try to reboot your computer.
Make sure your bios defaults to the disk which has the master boot record. usually it's in C drive.
Let me know.
Thanks.
Oct 22, 2008 | E-Machines eMachines Desktop PC
Disk boot failure
sounds like a hard disk drive problem. If you are comfortable with working inside your computer, you can open the case and remove the cables to the hard disk, and re-connect them again firmly.
Jul 07, 2008 | Computers & Internet
HP Compaq Presario SR2013WM (RE468AA#ABA) PC Desktop Logo
185 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
