Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
The color on my 3 year old 32" Bravia TV is primarily blue and green. The red and facial tones have basically disappeared. I have tried adjusting the color to no avail. Do you know if this is an adjustment or repair. if its a repair what is the component, the approximate cost of repair and if there are any repair sites in the Pittsburgh area. Thanks Don
  • boss807 Jul 02, 2009
    It was the Red LCD cable. It was loose - thanks.
    Don
  • 749 Answers
Hi, it could be the LCD cable It's called It's called Red Solarization. It could be the LVDS cable..or the panel control board...or the panel itself..some control boards only come with panel..unless you've changed a panel before I would advise you to take to a repair shop now the price will vary, if its the lcd panel it self the price could range 400/700 USD however this is less likely or it could just be the Red Solarization (lcd cable) which will cost 20/30USD. either way i would reccoment taking it to the repair facility here is a list of places.
Regards
Muzzi_123
Posted on Jul 02, 2009
Tv is 10yrs old. Started with color only red and blue, standby blinking, now nothing. Had something like this long time ago is this worth fixing?
propably green not working. due to age its hard decision its worth or not to repair, but i recommend to sell for a few bucks to a hobby-freak and buy a new one...
Nov 13, 2011 | Sony FD Trinitron WEGA KV-32HS500 32" TV
While watching TV - I heard a slight click noise in the remote and the screen color immediately changed color to predominately green ( still see blues and yellow) but red spectrum is not working ?? I have...
U have all the tools and can u also do basic soldering?Tv might have cold sodering joints on the CRT video board socket that connected video board and the CRT tube together.Must take tv aparts and resolders all the CRT holes sockets of the video board.Also resolders the Yoke wires R,G,B connections to the main board too.Should solved this problems.U can't do this,than u must hire a tv Tech to do the repair,sorry.
Feb 25, 2011 | Toshiba 32A33 32" TV
Poor Picture
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the curser (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It taked time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
Hope this help....
Jun 26, 2010 | Sony Bravia KDL-32V4000 32 in. LCD TV
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Jan 03, 2010 | Toshiba 27AF45 27" TV
Coloration - poor picture
TRY UNPLUGGING SET FOR A FEW MINUTES...PLUG IN LINE CORD WHILE HOLDING PRESSING POWER BUTTON..IF THIS DOES NOT WORK..CPU BOARD IS FAILING...P/N 667-L32K5N-56I...TRY CALLING MCM FOR PARTS AVAIL/PRICE...JOE ACE
Jun 05, 2008 | Insignia IS-LCDTV32 32 in. Television
My picture has a green and blue hue to it.
After spending a day trying to fix the TV, I found out the problem was actually with my cable box. I have an HD DVR recorder. We unplugged the cable box and plugged the TV directly into the cable in the wall and it worked. So we took the cable box back to our cable company and got a new cable box. (Can't live without the DVR!!)
Apr 28, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Connecting old DVD player to LCD
Just respect the colors. Green output from the dvd to green input tv, Red output from the dvd to red input tv and the same with blue. All 3 cables (green , red, blue) are for the picture, so you got to plug another 2 for the sound.
Dec 25, 2007 | Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
Bravia Color
why can't you adjust the color? What do you mean
Dec 22, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Colour distortion on tv screen
as you say pink& green means red+blue= pink &green means you are getting all color like b+g+r so it requires adjustment only please call skilled person to do it.
Oct 01, 2007 | Televison & Video
Sony bravia lcd tv-
If you are using a HD cable box or satelite with component outputs, be sure that all 3 cables ( green, red, and blue ) are making good connection.A loss of red or blue will cause color shift. Usually,if the tv menu comes up as the correct color but the picture dose'nt, it is most likely a signal problem.
Jul 01, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
62 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
