Question about KitchenAid 24 in. KUDS25 Built-in Dishwasher
Dishwasher Kitchenaid KUDS25SHHBLO
I NOT WORKIN WELL, ONLY WORK WELL THE SHORT WASH OPTION, ALL OTHER OPTIONS FOR WASH IT WORKS BUT THEY HAVE FLASHES VERY FAST WHERE YOU SEE THE TURNS OF ALL LIGHT AND THE DISHWASHER FOR LESS THEN A SECOND
    Problem Solver:
  • 5 Answers
It sounds like your touchpad is faulty. It can be removed by opening dishwasher door and removing 4 Torx screws along upper edge. Be sure power to unit is off before working on it.
Posted on Jan 25, 2008
I have kdte104dss0 dishwasher. Top rack will not pull out completely. Is there a way to fix this?
It seems that you need to order a adjuster assembly, slide rails for the top rack of your dishwasher. You can follow the below link to order the parts: http www searspartsdirect com model part kdte104dss0 0593 0130000 w1312023.
Jun 19, 2016 | KitchenAid KDTE104DSS Architect Series II...
Can you open the door to begin wash cycle and then close which will allow you to mount flush with cabinets?
Actually, I think it is designed to do that - select your wash cycle and options with the door open, then press Start, and then close the door within 3 seconds and it should run.
Dec 13, 2014 | KitchenAid KDTE204DWH Architect II Superba...
Fisher washer stays on clen for over 3 hours
"Fisher washer stays on clen for over 3 hours" ???
I think you mean the "Dishwasher stays in the clean cycle for over 3 hours", right? First question is "What cycle?" If it's the Pots and Pans cycle, or "Pro-wash cycle" , or "Normal cycle with extra wash heat or sani-rinse options selected, then yes, this is normal! A Normal cycle (without added heat) will take about 2 hours. And a short or quick or 1-hour cycle will take less.
Sep 25, 2014 | KitchenAid Dishwashers
Clean light flashes
I have found 2 possible solutions for you to try on your washer. It looks like there are good results on each of the sequences listed so you may try both to see what one works for you.
1) Press normal wash and heated dry one after the other about 5 times.All lights on panel will light.Wait until all lights go out and it resets itself.It will go into a mode on it's own.Then press cancel and set your options as you normally would and press start
On the hidden button models this seems to work, push these buttons in this order:
Heated Dry, Hi Temp Wash, Heated Dry, Hi Temp Wash, close the door, Start, open the door, Cancel 2x
Mar 08, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
My KitchenAid dishwasher quit workin no light no nothin, float switch is good, having problem troubleshooting water fill valve with solenoid???
Hi
Thanks for using FixYa. Please check for the following if your dishwasher is not working--
1. Fuse (blown or tripped).
2. 120 VAC supply wiring connection faulty. Repair or replace wire fasteners at dishwasher junction box.
3. Electronic control board faulty.
4. Motor (inoperative, check resistances).
5. Door switch (open contacts).
6. Door latch not making contact with door switch.
7. Touch pad circuit defective.
8. No indicator lamps illuminate when START or OPTIONS is depressed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 18, 2009 | KitchenAid Dishwashers
Child Lock on or Flashing Energy Saver Dry
I suspect that the cycle "button" on the control panel is intermittent.  Try using a different cycle - If you always use "short wash", try the "normal" cycle.
This worked for me.  It will be too expensive to repair, so I am dishwasher shopping.
Dec 30, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
KITCHENAID DISHWASHER DOOR PANEL
www.applianceart.com has many options for you to choose from. They sell many different panels to put on your dishwasher. If you call them (678-727-4747 x32) they can also send you a metal stainless plate that is easily installed. I think the metal ones are around $99.99 and the other options are $39.99
Sep 19, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
105 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
