Question about Posiflex PP7000 Printer
Unable to print Arabic characters by posiflex PP7000II-C printer. How can I resolve this issue? Thanks. my email id is jijomjose@gmail.com
I want to check my email account on someone else's computer , but am unable to get there ....????
There issues can be:-
1- Browser Problems
2- You forgot password
3- Check for Capslock
4- May be you are entering wrong email id or password
Dear do not worry it's not big issue, here in your question you did not write about email id which you want to login..provide me your email id or you can directly contact to online Gmail technical support number 1-888-551-2881.
Refer website-
Gmail Password Recovery
Oct 19, 2014 | Google Gmail
I have a cannon ir3300i printer is not taken print..computer says out of paper printing..but paper is available in printing..how to resolve this query mail id internetstation2012@gmail.com
try turning off both devices - start you computer first, then start your printer and see if that fixes your issue. if not try again this time leaving out the plug that connects the computer to the printer and then when the computer is turned on turn on the printer then plug it into the computer
Aug 08, 2012 | Canon (6981A002AA) for imagerunner 2200,...
Hi There We have got a HP Laserjet P4014 in our office which is on the network and and used by 10 PC's. Recently it has started to print junk characters no matter what we print or from which PC we...
check out this thread:
http://www.fixyourownprinter.com/forums/laser/32906
this covers printing of garbage characters comprehensively.
you can start off by checking your printer cable. and if that does not help, go through this thread.
Jun 08, 2011 | Office Equipment & Supplies
Printer character very small , how to character normal
A character set is presented with which unscaled 2D molecular structural diagrams can be constructed. A minimal subset has been implemented in ROM on CBM microcomputers, whilst the complete set has been defined as a character font on an ICL PERQ computer. Structural diagrams have also been output on dot-matrix and daisy-wheel printers using appropriate software to print the special characters. The character set provides a simple means of displaying molecular structures on inexpensive microcomputers, on printers and on hardware offering user-definable character fonts.
Oct 25, 2010 | Posiflex PP7000 Printer
Some of my E-Mails cannot be printed when I get a notice of "Unknown printer problem" on my Canon printer
It would be hepful to know the printer model number.
Also, since when are you facing this issue?
Are you getting this issue printing from a particular computer?
If so, you might want to remove and reinstall the printer once.
Please try to reset the printer once. That might help.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
Oct 05, 2010 | Office Equipment & Supplies
Dear expert pos machine(ibm SureOne100 Type :
looks like its running on IBM PC DOS. code page 708 - arabic. https://msdn.microsoft.com/en-us/library/cc195061.aspx however if you are using windows, then you may need an arabic windows, just adding an arabic languge file wont help. IBM PC Dos doesnt have an arabic option. you can download the ibm surepos 100 4613 technical reference manual which is what i did for you. but it no help in that arabic is not an option. research using arabic with DOS. because your keyboard is basically a PC one working in DOS.
Oct 03, 2017 | IBM SureMark Printer TF6 Thermal Label
Incorrect character printing.
On the L. side of the keyboard is a slide switch labeled 15, 12, 10 and PS it is probably in the PS position. If it isn't then slide iy up snd down a few times they do get dirty.
DickyO
Mar 26, 2010 | Nakajima AE-830 Typewriter
Zebra TLP 2844, Code Page for Arabic Character Problem
Download a free "Arabic" true type font. Use Zebra Designer to print your label and use the arabic font to print any character.
Apr 16, 2009 | Zebra TLP 2844 Label Printer
Crazy characters start to print when printing from pdf doc or certain websites
I understand that the printer is printing garbage when you are trying to print from internet.
Please follow the below given instructions to resolve the issue.
This issue can occur if the data send from the application from which you are printing, is using the PC-8 character set. This will produce a smiley face or garbage charters each time an unsupported escape code is sent by application. To know the character set, please contact the manufacturer of the application.
Also, you can follow these steps to disable the power managment in the comoputer.
1. Right-click My Computer, choose properties
2. Click Hardware tab, click Device Manager button.
3. Click the + next to Universal Serial Bus Controller.
4. Right-click USB Root Hub, choose properties.
5. Click Power Management tab.
5. Uncheck the option "Allow the computer to turn off this device
to save power.
6. Click Ok.
If the issue persists, follow the instructions from the below given weblink to resolve the issue.
Here is the web document:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=bpu01105&cc=us&lc=en&dlc=en&dlc=en&lang=en
Just copy and paste the entire link into the Internet browser's address bar and press enter.
This should resolve the issue.
Regards,
Lawrence
Nov 13, 2007 | HP Photosmart C6180 All-In-One InkJet...
Posiflex PP7000 Printer Logo
173 people viewed this question
Top Posiflex Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Posiflex Office Equipment and Supply Expert? Answer questions, earn points and help others
