Question about Panasonic TY-LA1000 Projector Lamp for PT60LC1
Set timer i replace lamp but how do i reset timer
  • 10,594 Answers
You did not post model number of TV so try below method to reset lamp timer.
Turn TV ON, Press and hold Volume minus button on TV and press Split/ Play button on remote for 6 seconds, lamp reset message will appear on TV screen.
Posted on Jul 02, 2009
The machine starts, eventhe vent, but no image appears. All the lights, except the POWER SAVING one remain lights on.
  • Plug the projector into the wall and put it into standby mode. You should have already replaced the projector's lamp with a new LMP-P200.
  • Press the "Reset," left arrow, right arrow and "Enter" keys on the projector's control panel. Press them in the exact order listed here, one after another, and press each key for less than five seconds.
  • Turn the projector on with the "Power" button. Press the "Menu" key to enter the projector's menu settings.
  • Press the down arrow to navigate to the "Install Setting" menu and press the right arrow to select it. You should see the lamp timer at the bottom of the screen. If you have correctly reset the lamp timer, it will indicate 0 or 1 hours.
  • Press the "Menu" key to exit the menu system.
  • Read more : http://www.ehow.com/how_6900249_reset-lamp-timer-sony-vpl_px20.html
    How to Reset Sony Projector eHow
  • Turn on your Sony projector after replacing the lamp.
  • Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
  • Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
  • Read more : http://www.ehow.com/how_7196165_reset-sony-projector.html
    Jul 02, 2015 | Sony VPL CS4 Multimedia Projector
    How to reset the lamp timer for Sony Projector vpl-px32
      Instructions
        • 1 Turn on your Sony projector after replacing the lamp.
        • 2 Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
      • 3 Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
    Jul 07, 2014 | Panasonic PT-44LCX65 Television
    Temp and lamp lights flashing
    can you let the projector work well
    if the projector projects the image,
    does the projector light?
    if the projector work well ,but the indicator lights flashing,that means the projector is ok ,
    you only need to reset the timer of lamp and to reset the timer of the filter,
    menu-setting-advance-reset-the timer of the lamp
    menu-setting-advance-reset-the timer of the filter
    Apr 28, 2014 | 3M S15i 165Watt 2000Hrs HSCR Projector...
    How to reset lamp timer
    The operator's manual has no reference to a lamp timer. The only user setting associated with the lamp is "Energy" for setting the lamp power to Standard or Bright. I'm surprised; most LCD RPTV sets have a timer that should be reset after replacing the lamp, and the instructions for doing so are given in the manual. The manual for this model only says to replace the lamp if the picture is getting dimmer (page 77).
    Sep 24, 2012 | Mitsubishi WD-60737 TV
    Having trouble setting timer o ML200RT
    Set on-off times by setting trippers
    -Insert trippers
    -Red tripper is ON
    -Black tripper is OFF
    -New timer has 2 sets of trippers
    Set time
    -Plug-in & turn-on power pack
    Turn dial clockwise to set time of day
    Manual override:
    Turn manual-on-off switch counterclockwise
    Troubleshoot:
    -Power pack not turned on
    -Plug does not have power > try hair dryer in plug to see if it turns on, check GFI breaker in bathroom, replace plug
    -Manual-on-off is set to OFF > rotate to ON
    -Outdoor lamp burned out > test with another lamp
    -Important to replace burned out lamps promptly, or other lamps burn out quickly
    -High household voltage will reduce life of timer
    -Timer designed to last for many years under normal conditions
    Sep 22, 2010 | Malibu ML200RT - Low Voltage Power Pack...
    How do i replace the lamp
    remove the lamp door on the bottom, remove the lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
    Oct 27, 2009 | Sanyo PLC XU35 Multimedia Projector
    remove the lamp door, remove the old lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
    Oct 15, 2009 | Sanyo PLC-XP55 Multimedia Projector
    Lost the manual - I am replacing the bulb
    remove the lamp door, remove the lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
    Oct 08, 2009 | Sanyo PLC XU35 Multimedia Projector
    Go to the menu and you'll find lamp timer section.
    Aug 27, 2008 | Vivitek V37835 46 in. LCD Television
    Lamp timer reset?
    I believe on this set it is actually in the customer menu. About 4 screens and it is second option to reset the lamp timer.
    Jan 21, 2008 | Panasonic PT-50DL54 50" Rear Projection...
    1,398 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    jasbo
    jasbo
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
