Question about Refrigerators
Roper Freezer Stopped Freezing
Last night, the icemaker on my Roper RT21LMXKQ03 started leaking, apparently where the water enters the icemaker in the top freezer. May have leaked for 15 minutes or more before I realized it. This morning, woke to find that the freezer is not freezing, and only as cold as the fridge. I only see a temp control for the fridge, so doesn't seem like I just bumped some setting. Could the leak have done something to the freezer?
  • 42 Answers
. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
Posted on Jul 02, 2009
I have a Roper RS22CFXTQ00 side by side. It leaks water in the floor. Water gathers under bottom drawer in freezer then leaks into the floor. I also have a problem with the hose that feeds water to the...
first check for a hole that water should drain tru. it must drain under the ref. into a pan and then it is evaporated by the heat.. u need to go on the back of ref.,. look where water goes into the freezer and that will need to put some putty or soke tape to stop the air leak that is causing your spout to freeze.. try those. ok
Feb 11, 2011 | Roper Refrigerators
The water fill tube for the icemaker is blocked.
Replace the Dual water control valve found on the back of the refrigerator near the floor with a new one and thaw out the entrance where the water goes into the ice maker. Provide a model number found on the inside of the fresh food compartment wall and I'll try to help you find the correct part number for the water control valve. The water control valve is apparently leaking like a leaky faucet and it's freezing causing the problem
Apr 03, 2017 | Whirlpool Refrigerators
Roper refrigerator leaks
Good job! most people do not know about the evaporator drain.
I would check the tubing to the icemaker, icemaker inflow valve and, water filter.
Jan 23, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Water is leaking in side the freeze
It's the pump for the icemaker/water dispenser. When it goes bad, it just starts pumping water into your icemaker until it overflows into your freezer. You simply have to replace the pump. It's happened to mine twice.
You can very easily replace the pump yourself in about 3 to 5 minutes, and the pump only costs about 48 dollars.
Here's a link to the cheapest place to buy the pump: http://www.easyapplianceparts.com/MultiModels.aspx?ModelNum=RS22AQXKQ&searchTerm=&RefineSearch=0
The first time I had this repaired, the repairman charged me over 300 dollars. I did it myself the last time. All I used was a pair of pliers.
Jan 03, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Whirpool gold
I did some research online, and read that the Start Relay is most commonly the problem. My husband bought the part, (about $50) and reattached it to the side of the compressor....and was cold immediately! apparently a very common problem on these fridges.
Jan 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water leaking from freezer.
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 12, 2008 | Frigidaire 22.6 cu. ft. Side-By-Side...
Kitchenaid Icemaker leaking in big drips on front of freezer bins
Nov 24, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Roper Refrigerator - manufactured 12/99 - RT18DKXH W00
tata75,
Happy to assist you,
you said,
For the past three days, water has been leaking/freezing at an alarming rate. The freezer had about 2 inches of ice built up and the bottom of the refrigerator is holding water, too. Both crisper s were FULL of water. I don't know if the ice maker connection is broken or what. Looks like I have to cut off the cold water completely to the sink to get it to stop.
Sounds like the ice maker or its line is leaking the water to me. And obviously it will freeze in the freezer.
You need hands on service.
Our site provides service companies in your area.
bless you,
Please give me a good rating before you sign off
Thank You
Sep 08, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerators Logo
151 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
