I need to set up my carberator for the rocky mountain region
SOURCE: How to fix a leak fuel from the carbuator or primer for a atv arctic cat 500 2005
YOUR GOING TO HAVE TO TAKE APART AND PUT A BIGGER RUBBER O RING INTO IT.
SOURCE: arctic cat atv problems
If it has in line fuel filter it may be clogged also if tank is located in the rear you may have fuel pump problem. Most that set forward or above engine are gravity fed and have fuel on and off be petcocks with screen type filter in small bowl at bottom which can be removed and cleaned. The screen will above bowl threads in the petcock. Hope this helps,
