Question about Rangemaster Classic 90 (Electric) Kitchen Range
Ignition wont work, there is an electrical supply to the cooker
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    There is no "static charge" generated from the gas for ignition. The gas is ignited by an electric ignitor on gas ranges and it is controlled by the Electronic Oven Control (EOC) board.
    Problem Solver:
  • 12 Answers
If its a gas range, the electrical is usually for the clock and timers, while the ignition usually comes from a static charge generated from the gas itself.
Posted on Sep 09, 2009
    Guru:
  • 417 Answers
Yes there will be a cooker switch located somewhere in the kitchen & from that there will be a supply to a cooker point witch is a white box that is no bigger than a single socket.
there should or should have been a 10mm heat resistant flex running from that to your cooker.
if there is a flex then your ignition mite run off a 3volt battery.check your manual if not then try this web site :
http://www.rangecookers.co.uk/installation-guide-content,MGQJD.aspx
Posted on Aug 12, 2009
The grill and ovens on my Jackson Topline cooker have just stopped working, the rings work but none of the lights above the switches are on when they are working, any Ideas please? thanks.
I am not familiar with your model of cooker but I assume it is a gas cooker.
Gas cookers have safety devices in the oven and grill the hob rings do not need. I speculate even the domestic oven hasn't escaped the interference from the electronics industry and I expect the aforementioned safety devices depend on (low voltage) electronics and electronics depend on electricity - that the lights aren't working would suggest there is no (low voltage) electricity.
Even in the case of an electric oven the thermostat could be electronic and need (low voltage) electricity to work.
I suspect the internal power supply has failed.
Jun 17, 2016 | Ovens Ovens
My cannon duo cooker was working one day then next day the clock doesn't work, the ignition wont work theres no gas coming through to lite oven manually whats the problem the rings work perfectly
Gas ovens invariably have a safety thermocouple to cut the gas off automatically if the flame goes out, due to an interruption in the supply for instance. The thermocouple must be temporarily over-ridden for the purpose of lighting the burner and pilot and often the override is mechanical but considering the clock and ignition has stopped working it would be reasonable to assume your oven has an electrical or electronic thermocouple override.
It would seem either the mains supply to your cooker has failed or the internal power supply has a problem. With such a sophisticated oven, even if you had been able to light it manually, it is possible the temperature control wouldn't have worked.
Mar 26, 2016 | Cannon Kitchen Ranges
The electronic ignition does not work. I have check all plugs. It does not make a click noise, no spark or power.
You didn't say whether it is a piezo-electric spark generator or whether it is battery-driven?
Piezo-electric is usually fairly reliable in operation but has gone out of fashion somewhat because it generates only one spark at a time which often does not provide reliable ignition.
Battery driven ignition systems provide a much more reliable ignition as they produce many really good sparks. The ones I have encountered operate from a single 1.5 volt battery which is adequate for the task as long as there are no poor connections and a good current supply is available to the spark generator.
Unfortunately the cooking environment is not conducive to keeping things clean and grease can penetrate the push-button, the battery compartment and connections and grease and carbon can impregnate the insulators causing a short-circuit.
Mostly in my experience these ignitions work great when new but soon lose efficiency and stop working. The one on our cooker soon became almost a hobby needing fiddling around with so often before it would work that we now use matches. The cooker before last also had the same story...
Nov 02, 2015 | Grilling
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 27, 2011 | Ovens
I put rice to cook and i smelled something burning. When i checked the rice cooker, it wasnt working at all. All the lights went off and i checked the other power supply, it was still not working...
have your rice cooker replace for another new rice cooker ( to make sure, because it might be an internal short circuit) then call an electrician to check your electrical wirings.
May 12, 2011 | Black & Decker Black Decker RC5428 28Cup...
STOVES 900DFa not working
Probably a silly Q but does the clock come on?
My \\\\\\\\stoves needs the clock setting before the oven and ignition will work
Feb 14, 2010 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Looking for Ultrex II Electric Pressure Cooker Cord
Any generic appliance cord should work. You can try Home Depot or Lowes they have some cords. Just make sure you get the same gage and approximate length cord. You can also buy cords on line from appliance supply websites. Good luck. If you have any more questions please ask. Please rate me so I know if I helped. Thanks.
Dec 30, 2008 | Ultrex II 8Quart Rice Cooker
Cooker lofra
fuse in plug new one job done + wife turnd oven off ?
Aug 18, 2008 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Cooker keeps tripping the electricity supply.
If the main oven is electric, disconnect the heater element and try, if no trip operqates. then replace element.
Nov 22, 2007 | Belling CookCenter 151 Dual Fuel (Electric...
Range master toledo 90
I would follow these requirements if I were you:
The cooker must be connected to the correct electrical supply as stated on the voltage label on the cooker (This is obvious so far!). It should be connected through a suitable cooker control unit incorporating a double pole switch having a contact separation of at least 3mm in all poles (This means one of those big red switches with "COOKER" written on them). The cooker must NOT be connected to an ordinary domestic power point. The cable size used should be between 6mm squared and 10mm squared twin and earth. Where the installation is protected by a 30 milliamp sensitivity residual current device (RCD Breaker), the combined use of your cooker and other domestic appliances may occasionally cause nuisance tripping. In these instances, the cooker circuit may need to be protected by fitting a 100 milliamp device. This work should be carried out by a qualified electrician.
Oct 28, 2007 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Rangemaster Classic 90 (Electric) Kitchen Range Logo
822 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
