HP LaserJet 2840 All-In-One Printer Logo
henry Posted on Aug 31, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Yellewo does not print
I replaced yellow Color and when I print, the yellow color does not print. Even on supplies report page, the yellow color section at the bottom is blank where the yellow color should be printed. How can I fix.
Mister Danger
Level 3:
  • HP Master 5,631 Answers
  • Posted on Apr 30, 2015
Mister Danger
HP Master
Level 3:
Answers
5631
Questions
0
Helped
1199184
Points
47629
Take it to refill site and ask them to unclog with ultrasound. If still clogged, buy a new color cartridge
Steven Brandon
Level 3:
Master:
  • Master 462 Answers
  • Posted on Aug 31, 2014
Steven Brandon
Master
Level 3:
Master:
Answers
462
Questions
0
Helped
117862
Points
1705
Must replace the nozzle/ cartridge carriage as the nozzle for yellow is most likely clogged
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
1 Related Answer
Anonymous
  • 2306 Answers
  • Posted on Dec 22, 2009
SOURCE: I replaced both cartriges (Black and Color) and
You can dab the bottom of the color cartridge on a damp paper towel, check the streaks left behind, if there is no yellow either there is no yellow in the cartridge or it's just plugged. Dab it a few times on a wet towel, if still no yellow, you need another cartridge.
Testimonial: "Thank you. You were right on! Sadly enough, this is the second consecutive cartridge that was without yellow. Is this a common flaw from HP?"
Why do I have yellow horizonal lines on printed page
Sounds like a faulty toner cartridge. Are all the cartridges OEM?
Magneta Color (Toner) and when I print, the Magneta color does not print. Even on supplies status page, the yellow color section at the bottom is blank where the yellow color should be printed. How c
The Magenta or RED toner cartridge should be removed and double check that you have indeed removed the pull tab located on the side of the cartridge which will remove the sealing tape off the new toner cartridge.
The YELLOW toner cartridge on the other hand if it is not new then it is perhaps empty and needs to be replaced. Another option is to remove the YELLOW toner cartridge from the machine, Tap it and shake it side to side to loosen the toner that is in it, and replace it back into the machine, this will usually make it start to work again!
Good Luck!
Rich Lilja
2answers
Yelllow color is not printing
check yellow cartridge to see if toner seal tab has been pulled out
The logo in my print job is color Green but its coming out in color blue. what is the problem
Check the yellow toner cartridge, printing a configuration page.
Configuration page
The Configuration page lists the current settings and properties of the printer. You can print a
Configuration page from the printer or HP Toolbox. To print the Configuration page from the printer,
complete the following steps.
1 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select the Reports menu.
2 Press the button (SELECT).
3 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select Config report.
4 Press the button (SELECT) to print the Configuration page.
Yellow print OK?
No? try print with another yellow toner cartridge (Q6002A).
ESP9 color prints begin coming out purple like
Use only original ink cartriges, the non original has ink normaly is not for you printer, and you wast your money and damage the printer print-head
6helpful
2answers
I replaced both cartriges (Black and Color) and when I print, the yellow color does not print. Even on the test page, the color setion at the bottom is blank where the yellow color block should be printed....
Won't print in color
All cartridges are new...report shows 0 pages for yellow left yet all others added at the same time show thousands of pages left. Everything printed is in black with no color. BTW: I have 3,000 pages left with black cartridge and the display says I need black.
What should I do?
7helpful
Color toners are empty
Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies. Change from stop at out, to override at out. It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
Dan :-)
k24674
Grand Canyon Tech
Grand Canyon Tech
