Hotpoint wd960 is noisy on the spin cycle and getting louder by the day,what can be the cause and how do i fix it ?.
SOURCE: noisy spin loose drum
drum bearing need need bearing kit and drum support £60 plus labour at similar price. Appliance Doctor
SOURCE: hotpoint ultima wt960 washing machine noisy on spin
Bearings faulty or another fault this model suffers from is the concrete balance weight retaining bolts shake loose, if it is the bolts tighten up as soo as possible. Regards Advisor
SOURCE: My Maytag PAV2300AWW Performa is noisy on spin cycle
If you are talking about a loud sqeaking noise, this is usually attributed to a worn snubber ring and/or brake assembly. You cannot lubricate the snubber to get rid of the noise. In fact, you may damage the washer if you do. A small amount of corn starch can be sprinkled under the bottom tub support where the snubber ring is to get rid of most noise related problems (this will be the bottom round plate where it meets the casing of the machine). However, if the snubber is worn too much, or if the brake assembly is worn they must be replaced. I would recommend replacing the following parts:
Brake Stator: 1057484 Price: $7.45
Brake Rotor and Lining: 1032674 Price: $16.70
Snubber: 1055142 Price: $4.35
Brake Removal Kit: 997909 Price: $99.40*
*Brake removal tool is required in order to remove the brake assembly and/or to replace the snubber. There is a 200lbs spring located under the Brake Stator that must be compressed PRIOR to removal or you could cause injury to yourself.
You can find all your parts and information at repairclinic.com. I am not affiliated with the website. I am merely recommending them because I have used their service before. Plus, they use the same repair parts as your major appliance repair companies, but at a lower cost.
The parts required to make the repairs aren't very expensive, but the tool required to do it IS. Also, if you've never worked on this type of washer before, this is not a job that I would recommended to the average do-it-yourselfer. Maytag is real good abpout providing the necessary instructions with their parts, but this is a bit involved.
Post back with comments and let me know if this helps you.
SOURCE: danby washing machine noisy only during spin cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
SOURCE: Hotpoint Aquarius WMA54 very noisy during spin
Hi, if your H/P is noisy on the spin cycle, just open the door and turn the drum a few times. If you feel some play, or kind of loud huming noise, then it is the bearings, very, very common on H/P WMA's.
