If you are not able to pass the boot screen, you can reset the tablet back to factory settings. However, this will delete all data in the storage card.
Here`s how to:
1. Turn off the tablet
2. Press volume up and power then hold
3. Let go if you have the android menu
4. Select Wipe data/Factory reset then reboot.
If you have the same problem that you cannot past the Jelly bean screen, you may have to reinstall the Operating system of the device. However, I do not suggest to do it your self as it will take time and has complicated steps that may cause damage or corrupted data on the Unit.
SOURCE: I would like to reset my DWL-730AP to factory
Unplug everything from it except for the power supply.
Hold the reset button as you did before. After you release and it resets, plug in the Ethernet cable.
SOURCE: Forgot custom password, have reset router and also
Hi Friend,
You have do a reset for your router
Step 1:Take a pen or a paper clip and insert it into the reset hole and hold it till the lights are getting flashing
Step 2:Once its flashing with out taking the hand from the reset unplug the power cable of the router and put it back after 10 to 20 secs
Step3: Then follow the below link to configure the Belkin router
http://www.fixya.com/support/r4364415-configure_brand_new_belkin_routers
If you have any Clarification please contact us any time
Regards,
Ayyasam
SOURCE: Need to reset password. D-link DIR-615 Wireless router
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
SOURCE: I forgot my password to
To reset the D-Link back to the default settings, Press and hold the RESET button and then power up the D-Link. Hold the RESET button for 5 secs until the LEDs flash.
Now you can enter the default login & password.
SOURCE: Forgot password to network. Trying
To reset the router to the factory defaults, press and hold the Reset
button for more than five seconds. This clears the router's user
settings, including User ID, Password, IP Address, and Subnet mask.
To re-configure the router, see Section 3: Configuration.
from the manual
http://broadband.motorola.com/consumers/products/WR850g/downloads/WR850G_userguide.pdf
I’m happy to help further over the phone at https://www.6ya.com/expert/thomas_b83e841f114394f4
