Question about Trekstor DataStation maxi m.u SATA 3.5" 500GB portable hard drive black 500 GB USB 2.0
I have a Trekstor 640m GB externaal hard drive. at first window recognizes the device then a message appears usb device not recognized, shows malfunction. what is the solution. is there a separate usb driver for this device. help pls james
  • Cliff Rodrigues Jun 08, 2013
    My Trekstor 500GB used to work and now any computer recognizes it as a corrupted name and will not open the drive:
    TrekStor did not naswer my email sent ot their customer care dept.
    Scholar:
  • 85 Answers
You might want to check out this link from Microsoft. See if this might help you:
http://support.microsoft.com/kb/871233
Posted on Jul 02, 2009
I have a trekstor hard disk ,model number-MSMTU EM s 8,and it is not getting recognized by computer
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 14, 2011 | Trekstor 88570 MovieStation maxi t.u 1TB...
Its is blingking red ang blue and say driver not recogniced
hope this helps
Apr 10, 2011 | Trekstor DataStation maxi m.u SATA 3.5"...
I want to format my kingstone Usb drive. but when i plug in the computer it shows me message that your usb drive is not recognize. I am using Microsoft Windows Xp SP3. i had checked in device manager but...
the only logical answer would be that you have updates available from microsoft that are disabled. youll need to allow these to download and instal before this will work.
Dec 20, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Just need to ask, trekstor external HD light is
Hi, unfortunately your are probably right. You can buy a new hard drive and install your self as the cheepest option?
Jul 10, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
Kingston 2gb datatraveler malfunctioned
there is absolutely no problem in your pc .
your pen drive is faulty.
Feb 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
USB Device Not Recognized...
try to the laptop firewire port, if works. I didnt find any support for youfirelite drive
Dec 29, 2009 | SmartDisk FireLite 40 GB Hard Drive
DataStation maxi m.u 250 gb
Does windows creates a drive letter for it?!
in "my computer" click "Manage"
and then "Manage disks"
does it shows up?!
If so, right click and assign a drive letter, try it now.
Sometimes, if you're using network drive letter assignments, windows messes up with upcoming pen drives or usb disks.
Sep 15, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Un recognized drive
what you should do is search for a driver for it so put the name of the usb then driver in a search engine and download and install a driver this should make the computer able to recognise the usb's software
Apr 04, 2009 | Western Digital WD Passport 250GB Portable...
Drive Being Recognized as Removable Disk
Use EASEUS Data Recovery Wizard to recover the data. You can find the program on the internet..
To format afterwards click Start, click Run and type compmgmt.msc.. In there format your drive..
Mar 10, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Trekstor Storage device
I have an answer on how to fix the Trekstor Datastation "Removable Disk" problem.
I also own a Trekstor Datastation 500GB and had the same problem even though it worked for several months then all of a sudden when I tried to hook it up to another computer, it stopped working. It would recognize the USB connection but you could not read the drive as it would say "Removable Disk".
In "Device Manager" it recognizes the drive as Sundata USB2SATA. But what it really should be is "WDC WD50 00AAVS-32ZTB0 USB Device" or something similar to that. For those that are wondering, yes, the hard drive is a Western Digital Hard Drive. Western Digital Caviar to be exact.
Solution: You need to open the cover to the hard drive and reconnect the hard drive to the connector on the board. It's that simple!
It is very loose and this model is not well designed so it can easily come off if you accidentally knock over your hard drive or move it to another location. The hard drive is held in place by screws on a holder where there is room for the screws to slide if the screws are not tight enough.
You'll need a T10 screwdriver bit to remove the cover and a Phillips screwdriver to adjust the hard drive.
NOTE: Doing this will probably voids your warranty but trust me, it works and it's really easy and quick to do. Took me 15 minutes.
May 03, 2008 | Trekstor Datastation maxi t.u SATA 500 GB...
Trekstor DataStation maxi m.u SATA 3.5" 500GB portable hard drive black 500 GB USB 2.0 Logo
334 people viewed this question
Top Trekstor Computers & Internet Experts
Mohamed Ismail
Mohamed Ismail
Alun Cox
vojvodabudva
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
