Question about Whirlpool MH1140XM Microwave Oven
Replaced lower light. It flashed. Now the light
Replaced lower light. It flashed. Now the light won't work at all. Everything else works.
  • 28 Answers
With this model you should unplug it first. More than likely it is a burnt track/trace on the controller board between the relay and the header going to the light. Easy to fix if you have a soldering iron, short piece of solid wire etc. Accessible from the front, just take off the top grille and then the one screw for the control panel.
Posted on Feb 26, 2010
The lamp of won't work
follow the steps and fix it. God bless you
ight Bulb
If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
Main Control Board
If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
Light Bulb Socket
If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
Jun 11, 2013 | Neff H5642 Convection / Microwave Oven
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
My light won't turn on and it isn't the bulbs being burnt out
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
That would be a problem on your controller assembly, which I can repair for $54.95, which includes insured return US shipping.
I would need to know the full model number from the tag on it, and the FCC ID number can be helpful, too.
Please contact me directly for full details since FIxYa doesn't always inform us of follow-up questions.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Dec 06, 2017 | Microwave Ovens
I have Problem with my microwave
it may be just a fuse , but if the fuse inside the microwave blows again then there is something else wrong and it would need to be tested to find the problem and fix it
so the fuse inside needs to be check and or replaced and if the microwave powers and works ok after replacing the fuse , then the other fuse was just bad
Jan 11, 2009 | Emerson MW8108P Microwave Oven
No lights not working at all
Model JVM1860SD001 lights quit working. Replaced all 3 bulbs (2 in range and 1 oven light). Everything else works fine.
Oct 03, 2008 | GE Microwave Ovens
GE XL1800 Suface light
This is a problem with the control panel assembly, which we repair nationwide for $39.95. Details are at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Jul 21, 2007 | GE XL1800 1100 Watts Microwave Oven
Whirlpool MH1140XM Microwave Oven Logo
217 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
