Question about Dual Electronics 6-24x50 AOE DUAL ILLUMINATE MIL-DOT RIFLE SCOPE
Where can I send to reapair my pentax scope ?
    President:
  • 1,185 Answers
How to tighten loose front glass lens on pentax gameseeker rifle scope
You have to remove the front element carrier from the scope body and tighten the ring inside the carrier Now the funpart remove the thread protector then the gold ring making sure that the element carrier don't rotate while doing that Then count the rotations till you get the element out as that is important for the parralax free setup or you could just remove it and after repair reparrallax it your self YouTube has some vids on how to do that Threadloc the ring to hold lens tight inside the carrier reinstall carrier to maintube but you have to purge the tube of air and moisture to stop condensation inside the scope and fill with an innert gas Reparrallax scope if required and test zero
Feb 06, 2016 | Pentax Optics
Hi my name is steve boy in glad i found you guys I lost my box for my pentax scope when i moved and it had every thing in it battery, instruction book the hole lot i would like to replace whatever i can...
Did a search of the Pentax support site for your Scope. They do not offer on their site a download manual. But I did get their contact info for you. Give them a call to see if they will help you with this info. Hope this helps Fix Ya up.
PENTAX Customer Care
Toll Free: (800) 877-0155
Phone: (303) 799-8000
Jul 07, 2011 | Pentax 3X-10X 50mm Whitetails Unlimited...
How to set scope up by yd lines in scope,
dont even trust them,,,,if you use them with one make of ammo they will be off with another make of ammo,,,,,so test fire it,,
Nov 21, 2010 | Pentax Gameseeker Rifle Scope Warranty...
Windage adjustment will not adjust to the right - clicks but does not move the shot groups to the right.
if you have forsed the scope turrets you may have broken your scope,,,if the turret turns to the left set it to the center and change the scope mounts or pack out the scope mount with some strips of 35mm camera film 3 strips should do you,
pack out the eye end mount on the left side of the scope
Aug 28, 2010 | Pentax 4-12x40 Gameseeker Rifle Scope...
Took my Pentax 4-12X 40mm rifle scope mounted on a Remmington 7mm mag bolt action rifle to hunt antelope in Namibia, SW Africa. First shot on a fine kudo blew up his heart and broke off-side leg bone....
you got it in one there,,,its all down to "head butting the scope"!
your head **** has pushed the eye bell up the scope body and has pinched or locked the power adjuster ring to the scope body
you have only two choices send the scope off for repair,,or buy a new scope,,,done even think about trying to fix it as you cant,,
it will need a strip down and then a re-gas (to stop it foging up)
so if you took it to bits the scope would be distroyed
Aug 22, 2010 | Pentax Optics
Cap cover pentax 3x-9x scopes
You do not define "cap cover" as to whether it is a 'lens cap' of which the Objective Lens comes in varying sizes with the 3x9 scope depending on the model.
However, you should be able to find one in the size you need at most any Firearms supply store. I have even found a lens cap for a Leupold at a Walmart.
Barring that, go to; www.pentaxsportoptics.com, they should be able to help you in your quest.
Good luck. :)
Apr 14, 2009 | Pentax 3X - 9X 40mm Lightseeker XL Glossy...
Crosshairs on pentax 4.5x14x42 don't move
With modern rifle scopes the crosshairs do not move.They are designed so that the crosshairs are always centered.I have not seen a scope with crosshairs that move for about 40 years.If your scope has 1/4 minute clicks, then the strike of the bullet moves 1/4 inch at 100 yards for every click.1 inch for 4 clicks and so on.If you rifle shoots 6 inches high at 100 yards you should turn it down 24 clicks to strike dead on.Many hunters and shooters adjust their scopes to strike 1 1/2 inches high at 100 yards.Then it will be accurate to about 300 yards without further adjustment.
Feb 15, 2009 | Pentax 4.5X-14X 42mm Pioneer Matte Rifle...
I have a Pentax lightseeker scope and I can not get it adjusted and it has a cracked lense. The adjustments turn but nothing happens, I still shoot the same direction no matter what...
If it has a cracked lens it obviously took a very hard shot at some time or other.I would send it back to Pentax.They are not cheap, so I would attempt to get it repaired by the manufacturer.
Good Luck
Jan 28, 2009 | Pentax 4X - 16X 50mm Lightseeker-30 Matte...
Moisture in my 3x9 Bushnell Banner Scope
In the past, I have successfully dried out scopes and binoculars by them in a warm oven.NO MORE than 150 degrees and monitor them closely.Many plastic parts will melt at high temps and then you have an expensive paperweight.I have dried out my Pentax 12x50s ($300) several times.I should know enough to come in out of the rain but will probably never learn.Good Luck!
Nov 28, 2008 | Barska Optics Barska 10-40x50 Ao Varmint...
Dual Electronics 6-24x50 AOE DUAL ILLUMINATE MIL-DOT RIFLE SCOPE Logo
77 people viewed this question
Top Dual Electronics Optics Experts
james laughton
james laughton
ray gallant
Are you a Dual Electronics Optic Expert? Answer questions, earn points and help others
