Question about Palm Tungsten E Handheld
Tungsten E2 'fatal alert'' message
Please advise possible solution to following.
Item: PalmOne Tungsten E2, purchased 5/2006.
When synchonizing PDA following message appears during the sync process:
Fatal Alert
VFSDBCache.c, Line:4051, unattached record
[reset]
Conditions of message:
- synchronizing via bluetooth
- frequency of message: always
- no known loss of information / functionality
- sync appears to be accomplished successfully
  • 13433 Answers
SOURCE: Tungsten E2 PDA battery
E2 has a great battery might not be it. Its not easyly replaceable like in some other models.
the battery can be replaced by a professional or by yourself.
The pda should work on charger? does it work while pluged in?
If it doesnt work while its pluged in theres something more seriour wrong with it.
You can try soft and hard reseting.
Instructions can be found in this pdf file http://www.palm.com/us/support/handbooks/tungstene2/en/maintain.pdf
If you cant open pdf files you need to find yourself pdf reader, google pdf reader and get one.
If soft or hardreset have any effect and the device still doesnt work even on charger then it has a hardware issue and I recommend contacting palm or the place where you bought the pda and findout about repairs and possible price, may be high.
good luck and if theres anything else let me know.
Posted on Feb 19, 2008
SOURCE: Fatal alert [Memory Mgr,C,Line:3751, Free handle
I fixed mine this evening by doing a hard reset. First I removed the card just to make sure I didn't harm the data on it. Everything else is lost in the memory of the handheld by doing this but at least you still have a gizmo that works! Others have suggested to do stuff and then do a HotSync -- lovely, but the HotSync was also seized shut!
To do a hard reset:
  • While holding the power button, use the tip of the stylus (or a similar object
    without a sharp tip) to gently press and release the reset button inside the hole
    on the back of your handheld.
  • Wait for the Palm Powered™ logo to appear, and then release the power button.
  • When you see the message that warns you about erasing all of the info on your handheld, Press Up on the 5-way navigator to finish the reset and show the touchscreen.
  • NOTE: this last step will give you an option of pressing any key to simply do a soft reset. That's nice if it works because you don't lose any data that way. However, didn't work for me!
Posted on Apr 22, 2008
  • 23 Answers
SOURCE: tungsten e2 palmone driver help
You need to download palm desktop and hotsync manager from the palm website. Totally free. Found at.
http://www.palm.com/us/support/palmdesktop.html
Posted on Aug 04, 2008
SOURCE: Fatal Alert when doing hot sync on palm tungsten e2
you gotta do a hard reset. i had the same problem. go to the palmone website and look up how. make sure you back your stuff up in case you can't get things back. once you perform the hard reset the error should go away.
Posted on Nov 11, 2008
  • 89 Answers
SOURCE: screws for palm tungsten e2
T5 or T6
Posted on Mar 13, 2009
How to change from com 1
Palm (PDA) - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/Palm_(PDA)
WikipediaThe Palm Treo 700p is one of many smartphones produced that combines Palm ... Although HP kept the Palm brand initially, all new PDA devices announced at press ....In order to try to change this trend Palm had been working on a new ...
How to Replace the Battery in Your Palm Tungsten E2 PDA ...
? 4:34
https://www.youtube.com/watch?v=caJVwecskho
Sep 2, 2007 - Uploaded by Aaron Kelly
How to Replace the Battery in Your Palm Tungsten E2 PDA. Aaron Kelly ... for battery replacement. Includes one year money back guarantee!
[PDF]Handbook for the Palm Tungsten E Handheld - Textfiles.com
pdf.textfiles.com/.../PDA/PalmOne%20Tungsten%20E%20Handheld.pdf
Chapter 1: Setting Up Your Palm™ Tungsten™ E Handheld . . . . . . . . . . . . 1. System requirements . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Jan 03, 2016 | Palm Computers & Internet
Fatal Alert Datamgr.c,Line7564 InvalidUniqueIDPassed I get this when I synchronize.
Perhaps you haven't tried performing a more severe reset to break the freeze. You might want to try doing a hard reset. This will erase all data from your hand held so make sure you have everything backed up on your computer so you can sync it again after the hard reset. Note, when I occasionally receive a Fatal Alert error, the Reset on-screen button almost never responds to a tap...I invariably have to depress the reset button in the back of my E2. http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(26419) resets:
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(887) Depending on a variety of factors including the available memory on your E2 and other installed applications, the problem might or night not be caused directly by the program you were trying out. But once you get the E2 unfrozen, you should refer to this article to troubleshoot the cause of this apparent software conflict:
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(27908) Also, I recommend going to the developer of the software you are using, to determine whether there are any compatibility issues at their end, and whether they have an upgrade available.
Here are the directions for the hard reset.
1. Press and hold down the power button.
2. While holding down the power button, use the tip of your stylus (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld.
3. Wait for the Palm Powered logo to appear and then release the power button.
4. When you see the message that warns you about erasing all your data please continue and then follow the on screen directions.
If this doesn't help then I recommend going to www.palm.com. From there you will need to select PDA's and then the model of yours. It will go to another screen and you should be able to contact palm via free chat. I have had to do this several times and both times I got fast service. Hope this helps.
Aug 24, 2009 | Palm Tungsten E2 Handheld
Everytime I use the search fuction I get a fatal alert message
Make sure you have over 25% remaining space on your HandHeld and try again. Otherwise try a hard reset: Hold down the power button and click the reset button.
For more help:
admin@dec-help.co.cc
DEC Electronics Limited
www.dec-help.co.cc
Feb 26, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Tungsten e2
Take a look at your address and birthday sections and see if you can find duplicates bith in your PDA and you desktop.
Jan 05, 2009 | Palm Tungsten E2 Handheld
Nov 09, 2008 | Palm Tungsten E2 Handheld
Unable to hotsync with my computer
anytime you get fatal alerts you have to do more than just push the reset button. You will have to do a soft reset or possibly a hard reset,(usually the soft reset works) Google it and you will find it is quite simple to do
Jun 17, 2008 | Palm Tungsten E Handheld
Fatal Alert
Though Docs to Go is supported by Palmone, it is still a 3rd party software and will jam your unit like you wouldn't believe. I reloaded mine 15 times before I gave up and quit using it. The Fatal error is an all out jam. The Docs can even duplicate themselves and yes you end up dumping the program from your e2 and reloading before it will work again. The e2 is good and I made mine do internet wirelessly but could never whip Docs.
Mar 03, 2008 | Palm Tungsten E2 Handheld
Fatal Alert problem
We prayed and asked God to save the data even though we had to do a hard reset. Data was preserved entirely! For this we give thanks--and praise.
Rob Starner
Feb 19, 2008 | Palm Tungsten E2 Handheld
Installation
Got to the control panel, add/remove programs. Remove PalmOne if it appears there and try again.
You might want to download the latest version of the desktop from the PalmOne site.
Feb 12, 2008 | Palm Tungsten E2 Handheld
Palm Tungsten E Handheld Logo
122 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
