Toshiba e-STUDIO® 282 Black and White Copier
Problem for Toshiba e-STUDIO® 282 Black and White Copier
F103 ERROR CODE IN TOSHIBA E-STUDIO 282
By xeerie on Jul 02, 2009
we are facing a problem of code f103 in toshiba e-studio 282 model.kindly tell us what is the problem behind this code? and how can we solve this problem?
briefly tell us,we will be waiting for your kind reply
thanx
Best Solution
posted on Jul 02, 2009
Helpful)
didi2005
Rank: Guru  Toshiba Expert
Rating: 86%, 120 votes
F103 indicates HDD transfer time-out.
U can try format the HDD (08-690).
Then u perform the bad sector check (08-694). *take long time
If the check result is OK, recover the data in the HDD. If
the check result is failed, replace the HDD.
* replacement of HDD require firmware update
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Toshiba e-STUDIOŽ 282 Black
Questions and Unsolved Problems for Toshiba e-STUDIOŽ 282 Black
Do you recommend Toshiba e-STUDIOŽ 282 Black and White Copier?
Answer
Answer
My 4700n displays error 13.20.00 jam in paper path but no paper
Answer
my photo copier is not scanning when commanded
Answer
how to install sharp AR-5316 to windows vista business
Answer
image registration and size in left and right side is perfect but from top to bottom image... (More)
Answer
What is A4 error 164? My copier cant initialise beyond this error. Changed all trays and adjusted... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba e-STUDIOŽ 282 Black...:
Top Copier Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
