Question about Canon Office Equipment & Supplies
I have been getting a message that the "ink absorber" is full, and now I get a message with the error Message saying that I should turn off the printer, and back on and it should correct the problem, but it doesn't. What is the "ink absorber" and where is it? Can I replace it or what?
  • 1 more comment
  • jhhspark3 Jul 02, 2009
    I'm not good on computers, and I am 85 and much of your language I don't understand. Where would I find my ink absorber, and where can I get a replacement? This has never happened before, why would it happen now--have I done anything to cause it? Will Staples have a replacement? That is where I bought the printer.
    I have received to suggestions: 1; using water and a drinking straw, which sound strange to me. Is it? and 2; pressing the on and reset buttons. How will either of these correct my Ink absorber problem that initially you said I would have to replace?
    Yes, I guess I need a service center? Does Staples do that, or do I have to go to a Canon service center?
    Sergeant:
  • 326 Answers
Actually in inkjet printers the waste ink is collected in the ink absorber pad u r printers ink pad is full u have to replace with new ink absorber pad
Posted on Jul 02, 2009
  • 4 more comments
  • SABARI ANAND
    SABARI ANAND Jul 02, 2009
    The reset fixed a problem I had after cleaning the print head. A great
    tip for cleaning what appears to be a dead or clogged head (especially
    after using 'lookalike' cartidges) is to use a short piece of plastic
    drinking straw, a syringe, and hot water. Remove the printhead, then
    find a straw which will fit tightly over the ink pads inside the
    printhead, fill the syringe with warm water then place into the straw.
    Gently depress the syringe until clear water flows out of the head in
    several fine jets. Repeat for all 6 of the colours. Dry the the head
    and replace. One problem I had was that the yellow was pink/orange.
    What I hadn't noticed straight away was that due to a blocked head or
    maybe bad compatible cartridges, the red had actually syphoned back
    into the yellow, so no amount of cleaning would fix the problem. If you
    have bad colouration, might be worth checking each tank hasn't had it's
    colour contaminated.
  • SABARI ANAND
    1) With the printer power turned off, while pressing the Resume/Cancel
    button, press and hold the Power button. (DO NOT release the buttons.
    The LED lights in
    green to indicate that a function is selectable.)
    2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
    3)
    While holding the Power button, press the Resume/Cancel button 2 times,
    and then release both the Power and Resume/Cancel buttons. (Each time
    the
    Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
    4) When the LED lights in green, press the Resume/Cancel button 4 times (Each time
    the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
    5)
    After the function (menu) is selected, press the Power button. The LED
    lights in green, and the selected function is performed. (When the
    operation completes,
    the printer returns to the menu selection mode automatically.)
  • SABARI ANAND
    if this all fails buy new absorber pad
  • SABARI ANAND
    it is a common issue with most canon printers.....So the advice i like
    to share with u is,first u need to empty the waste ink tank absorber on
    the printer and would like to let u know that changing to a new
    cartridge would not solve this problem as this has something to do with
    the printer and not the cartridge.
    So once u empty the waste ink tank absorber (something similar to a
    small sponge..ie: it is the place where your excess ink goes. U should
    take off that ink as it has reached the maximum point of absorbing and
    it's unable to absorb more ink) your printer should work fine.
    Hope this helps
  • SABARI ANAND
    do u need service center address
  • SABARI ANAND
    try both any one will solve u r problem if didnt replace the pad
How to replace ink absorber
Maybe you can reset the absorber
Instructions
    • 1 Press the printer'sicon1.png "Resume/Cancel" button when the error message appears. This should clear the message temporarily and allow you to resume normal printing.
    • 2 Turn off the printer if Step 1 did not clear the message.
    • 3 Disconnect the printer from the computericon1.png, typically a USB cable.
    • 4 Unplug the printer from the wall electrical outlet for 10 minutes, then plug it back in. Reconnect the cable between the printer and the computer.
    • 5 Turn on the printer. Your sensor settings will reset, which should eliminate the error message.
Aug 21, 2014 | Canon PIXMA iP1700 InkJet Photo Printer
How do I Turn off my waist ink absorber error message?
You can't. You will need to replace the waste ink tank when it becomes full before it will allow you to print anymore. I had to do that with my Canon at one time too.
Aug 20, 2014 | Canon PIXMA iP4000 InkJet Photo Printer
I have error message E 8 What do I do?
Hi
Error E8 means waste ink absorber full. To clear this error you'll first need to clean the waste ink absorber. It is located on the right side when you'll open the front cover.
Please turn off the printer and unplug it before performing any operation. After opening the front cover use a paper towel to absorb off the excess ink on waste ink absorber. Wait for 2 minutes before plugging back the printer.
Please get back to me if you have any issues in performing this.
Daniel Scott
Jun 10, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Message" waste ink absorber"
There is an absorbent sponge in the bottom of your waste ink container to help contain the waste ink your printer generates when it cleans the print head nozzles. That sponge is probably full and has triggered a "most informative" error message!
Check your user's manual about the procedure for changing the absorber and where to buy new ones.
Dec 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I am getting an on screen message
The waste ink absorber covers the whole bottom of the machine, under the printer. It is difficult to change, and you have to get into the diagnostic mode to reset the error. A shop repair...
Jul 09, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Canon MP145 Ink Absorber Full Problem.
I got on error message when started to print.
It’s kept happened and message dialog box “The ink absorber is full” occurred.
Mine is Canon MP145.
Can somebody please help me , on how to fix this problem !
tq
Jan 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink absorber on canon iP 1600
u have to clean it mannualy by opening it. if u r not expert give the printer to qualified proffesional
Apr 01, 2008 | Office Equipment & Supplies
old marine
old marine
