Question about Garden
When I try to start my '98 MTD Model 690 lawn tractor there is a loud clicking noise under the seat, then after a while the engine might kick over and start. I thought it was the starter and replaced it, but it is still doing the same thing. The battery is only 2 years old. Can you help?
  • 490 Answers
The clicking is the starter solenoid and it sounds like you have a bad ground or a weak battery
Posted on Jul 02, 2009
I have a 2010 MTD series 760-770 lawn tractor. When starting, just getting clicks under the seat. Is there a solenoid to replace? No mention of one in the owners manual replacement parts list.
Diagnose & Troubleshoot - MTD Products
www.mtdproducts.com > Home > Owner's Center
MTD ProductsYou can use the Part Finder to help find your model and the right part for your machine.... Select your machine type below to start troubleshooting. We'll provide you with symptoms of common lawn mower problems to help you diagnose your .
Sep 14, 2015 | Mtd Garden
Need a wire diagram for my mtd 20hp lt lawn tractor
use your model number under the seat.
go search for a manual.
there you will find what you are looking for
Oct 18, 2014 | Mtd Garden
Wont trun to start
park brake must be engaged, cutting attachment disengaged, still no clicking sound? Lawn Mower Parts Genuine MTD Parts for Outdoor Power Equipment You will find the correct manual at this link
Apr 13, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
What is the correct belt size for yard machine lawn tractor 18 hp. with a 42" deck model # 136aq670g62?
Take your make and model number (located under seat) to your local lawn mower repair parts shop and they should be able to get you the appropriate belt.
If helpful, please rate.
Jul 11, 2011 | Mtd Drive Belt 42"
I need a manual for a 1998 or 1999 gardenway lawn tractor by MTD troybuilt Model #13AI617H118 Serial #1A082H10211 can you help? It's a 21H tractor 46SDIt's up above
Most of the MTD product manuals are available here: http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001 . Just fill in the model and serial numbers.
I found two separate manuals listed: lawn tractor owner's guide and the engine operator's manual. I found the manuals only opened in IE (Windows OS) after clicking the I Accept button. The direct links are: http://manuals.mtdproducts.com/mtd/Safety.do?pid=152292&model_num=13AI617H118&serial_num=1A082H10211&filename=770-10317b.pdf and http://manuals.mtdproducts.com/mtd/Safety.do?pid=152290&model_num=13AI617H118&serial_num=1A082H10211&filename=274794.pdf .
I hope this helps.
May 14, 2011 | Mtd Garden
I have a MTD ride-on about 3 years old which has an electrical problem. When trying to start the mower the engine doesn't crank. I can hear a "clicking" noise from below the seat. I would have thought this...
If you know that the battery is good, then it is the Magneto, (This is the part responsible for recharging your battery as you use the mower.)
However, your battery may be bad and no longer receiving a charge. Take it to a local auto parts store and they can test it for free.
Good Luck!
Jim
Sep 13, 2010 | Mtd 46" Dozer Blade, Fits All & Yard -...
I HAVE RYOBI (MTD) LAWN TRACTOR THAT HAS TWO
There should be two wires going to the seat switch. Stephen.
Nov 18, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
I changed all 3 belts on my MTD lawn tractor, now the engine turns over but will not start
check to see if you have spark to the plugs when you are cranking it over. If not then one of the safety devices is keeping it from starting. there is one under hte seat, one on the deck engagement lever and one on the clutch pedal
Aug 09, 2009 | Mtd LAWN MOWER PART # 753-0698 KIT-DECK...
Mower will not start. Makes a loud fast clicking noise when the key is turned.
Loud ticking usually indicates near dead battery, take it out and charge it. If it still ticks you may need to replace it as they are only good for a few years.
May 10, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
