Question about Logitech 3-Button Cordless Optical Scroll Mouse
Battery cover cannot get battery cover off
    Problem Solver:
  • 7 Answers
Flip ur mouse and u can see a small arrow button,Slide the button and the cover opens up
Posted on Jul 02, 2009
Laser 400. Where can I get a battery cover?
Battery Cover Nikon Sale‎
battery-cover-nikon.compare99.com/‎
Up To 70% Off Battery Cover Nikon
Battery Cover Nikon
Sep 30, 2015 | Nikon Optics
Tip
Nokia battery
<b>Remove the back cover</b><br /> Place the phone with the back of the phone facing you. Pull up the back cover from the finger grip at the top of the cover.<br /><br /><b>Note:</b> Always turn off the power, and disconnect the charger and any other device, before removing the cover. <a></a><span>Avoid touching electronic components while changing the cover.</span> Always store and use the device with the cover attached.<br /> <b>Remove the battery</b><br /> After you have removed the back cover, insert your finger into the finger grip, and lift the battery from its compartment.<br /> <b>Replace the battery</b><br /> <ol> <li>Insert the gold-colored contact end of the battery into the battery slot. </li> <li>Push down on the other end of the battery to snap it into place. </li></ol> <b>Replace the back cover</b><br /> Place the back cover on the phone bottom first so that the cover tabs align with the slots in the phone and press the cover moving from the bottom to top until the cover is securely in place.
on Mar 09, 2011 | Cell Phones
How to remove a battery on a samsung flip cell phone SCH-u36 ?
Just follow the discussion in the owners manual here: http://www.samsung.com/us/support/owners/product/SCH-U365HAAVZW
The battery cover on the back of the phone protects the battery.
Removing the battery cover
1. Hold the phone firmly and locate the Cover Release Latch.
2. Firmly "pop" the cover off the phone.
Installing the battery cover
Align the cover and press it into place, making sure it snaps securely.
Jul 25, 2014 | Samsung Verizon Gusto 2 SCH-U365 Prepaid...
Find the cmoss battery d505
Unplug the Dell Latitude D505 laptop from AC power. Turn over the so that the base of the computer faces upward. Locate the battery panel on the bottom of the computer and then press the latch on the battery panel in the direction of the arrow on the latch. Lift the battery from the battery compartment.
Press on the latch located toward the front of the computer inside the battery compartment. Pull the cover that is released out and down and remove the cover from the battery compartment.
Grasp the small battery in the slot uncovered when the cover was removed and pull the battery away from the slot to detach the battery from the laptop
Dec 12, 2011 | Dell Latitude D505 Notebook
How do i replace the battery in the garmin streetpilot c330
Follow these steps : 1. Determine that you do have a Garmin GPS with a replaceable battery. Find the information by checking the manual or with a close inspection of the back and sides of the GPS unit. GPS units that have a battery that can be replaced by the owner will have a battery cover lock on the back or side; it looks like a small sliding piece of plastic with slots or ridges.
2 Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
3 Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
4 Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
5 Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
May 16, 2011 | GPS
I have put fresh batteries in my Canon Power Shot S1 camera and it still will not come on? Can you help me?
Contact failures may have occurred between the camera and the batteries.
Confirming that the [Memory Card / Battery Cover] is securely closed
If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.
Close the [Memory Card / Battery Cover] securely, and then turn the power on.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.
If your camera uses four AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries.
1. Be sure that the camera power is off.
2. Slide the battery cover lock in the direction of the arrow, and push the battery cover slightly forward. Then open the cover.
batts_step1.gif 3. Insert the batteries as shown.
batts_step2.gif 4. Close the battery cover.
batts_step3.gif * For the PowerShot S2 IS, PowerShot S3 IS, and PowerShot S5 IS the batteries are inserted in a slightly different order, please refer to the decal inside the battery door for the correct order.
Installing batteries in cameras with 2 batteries. If your camera uses two AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries. Please see the various examples to find which type matches your camera.
Example 1:
  2. Slide the battery/memory card cover lock in the direction of the arrow (1.gif), and press down while opening the cover (2.gif).
  3. Insert the batteries as shown and close the battery / memory card cover.
Example 2:
  2. Slide the battery cover lock in the direction of the arrow, and open the cover.
* For the PowerShot A300 and PowerShot A310 the battery polarity is reversed.
Dec 05, 2010 | Canon Cameras
How do you install batteries in th eti-84 plus calculator?
The batteries go in the back, under the big rectangular cover. The release is just above the cover, push it down toward the cover then pull up and the cover should come off easily. Put the four AAA batteries into the slots, following the polarity indicators.
To install the backup battery, remove the screw from the cover and then remove the cover. Install the battery and replace the cover and screw.
Put the main cover back on by inserting the tab into the slot at the bottom and pushing the top back in.
Sep 07, 2010 | Texas Instruments TI-84 Plus Silver...
How do you open battery slot
(1)Remove the USB connector cover.
(2)Press and Move the battery cover in the direction of the arrow.
(3)Remove the battery cover and insert one AAA-size battery into the
(4)Replace the battery cover.
Jan 23, 2010 | Nextar MA933A MP3 Player
Where is battery
you need to remove 4 covers to replace the battery:
1. Cover over the windshield washer reservoir
2. Cover that says BATTERY on it
3. Cover that holds the battery cover
4. Cover over the bottom edge of the windshield on passenger side
Then you can access the battery easily! Hope this helps. let me know.
Dec 14, 2009 | 2006 Infiniti M35
Got a new samsung j700 today but i cnnot remove the battery cover I bought a new Samsung behold cell phone today and can't remove the battery cover on the phone.
Remove the battery cover. To do so, press the ridged area on the battery cover using your thumb (1) and gently slide it in the direction of the arrow (2). Remove the battery cover.
Place the battery so that the three brass tabs on the end align with the three brass prongs at the bottom of the battery compartment (1). Press the battery down until it clicks into place (2).
Replace the battery cover. Make sure that the battery is properly installed before switching on the handset.
Thanks.
Mar 27, 2009 | Samsung J700 Cellular Phone
Logitech 3-Button Cordless Optical Scroll Mouse Logo
79 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
