Question about Tomtom One XL GPS Receiver
Tomtom one v3. this unit will not power up at all. When i connect a power cable in i just get the green light. Any help ? thanks
  • steddly1 Jul 22, 2009
    Hi and thanks for the reply. The Tomtom i have has its card built in and would have to remove the back to get at it. I have a mains charger that i use and the usb cable has been tried. I have now been in contact with Tomtom and they want it sent to them for repair !! Looks like its going to cost me. Will post back when I know more
  • jcqueen
    jcqueen May 11, 2010
    Couple of questions:
    1) Do you have an SD card installed in your TomTom? If so, is it an SDHC (secure digital high capacity) card?
    The One XL doesn't support SDHC card, although it may seem to at first; after awhile it will begin acting erratically, rebooting, freezing, searching in vain for satellites, etc. Just replace the SDHC card with a regular SD card and it'll be as good as new.
    2) Have you tried plugging your TomTom into your computer via a mini-USB cable?
    Don't ask me why, but I have found that a computer connection sometimes has the "oomph" needed to jump-start a finicky TomTom.
    Good Luck
    Champion:
  • 243 Answers
go to tomtom.com, go to support, search for reset, select your device do as told. includes fotos of resetbutton and good discription. first make sure battery is full. goodluck.
Posted on Feb 12, 2010
TOMTOM GO LIVE 1000 Orange charge light will not
The battery is stuffed and needs replacing. It is a well know issue.
Aug 28, 2013 | Tomtom One Europe v2 GPS Receiver
My TomTom One V3 won't switch on. The green light shows it as charging but it won't power up. Tried reset as discussed with TomTom
If reset not worked, then must open up, take out battery and then reset, then you must hook up USB and upgrade software, also maybe need to get new battery too, often battery seems OK, but not,.
Apr 10, 2010 | Tomtom ONE 3rd Edition GPS
Tomtom One 3rd Edition will show green light but will not turn on
If you have an SD card in then remove it and try to boot it up.
It is possible that the SD card is corrupt or faulty.
If it does not power up with no SD card then it may well need to go in for repair.
Should you get it to boot without the SD card then back it up straight away.
Reformat your card (preferably in a card reader) and then restore to the card . You should then be able to put the card back in
Aug 20, 2009 | GPS
TomTom will not charge with car charger
Mine does the same, the light comes on on the charger, but not on the TomTom unit itself. There is clearly a loose connection in the cable somewhere as you can twist the flex and make it work, although this is not very reliable.
I just use a USB charger from an old phone instead.
Mar 30, 2009 | Tomtom ONE 3rd Edition GPS
Doesn' t turn on
1. Connect the TomTom to the USB for power (green light should be on).
2. Hit the reset button on the bottom of the device - you should feel it depress slightly.
3. Press firmly and hold the power button and count to 10.
5. Try this a couple of times if it doesn't work the first time.
Even if your battery is ****, the power connection has a pass-through, so you can still use the device as long as its connected to the charger.
Dec 19, 2008 | Tomtom GO 720 GPS Receiver
Tom tom will not charge using 12 volt charger
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
Nov 17, 2008 | Tomtom ONE GPS Receiver
TOMTOM GO 710
Could be a loose contact at the connection between the wire and at the gps unit.
Think the green light must be on at the charger port and also on the gps unit.
This green light can be found near the power button on the gps unit.
Nov 22, 2007 | Tomtom GO 700 GPS Receiver
Doesn' t turn on
reset the device by pushing the reset button near the plug on the bottom of the unit , then it will come on i presume you upgraded by the internet you need to use a paper clip to reset the unit
Sep 25, 2007 | Tomtom GO 700 GPS Receiver
Tomtom 300
Have you tried resetting the unit?
small pointy object in the hole marked 'reset.'
failing that...
http://www.tomtom.com/support/index.php?Lid=1
Sep 01, 2007 | Tomtom GO 300 GPS Receiver
Tomtom One XL GPS Receiver Logo
142 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
