Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
Troy built 6 75 hp lawnmower will not stay on I start it but it will quickly turnoff''
On the bottom of the carb. is a bolt that holds the float bowl on. remove that bolt and float bowl. use a small needle and stick it in the holes on the bolt to clean them out. look at the gas in the float bowl to make sure there is no water in the fuel tank .
Posted on Oct 09, 2009
    Genius:
  • 1,036 Answers
This may be a blocked airfilter. Try cleaning it and retry.
If you have the same problem, Replace fuel filter, clean out tank and use fresh fuel.
Check spark plug gap, and replace engine oil if used.
Posted on Aug 11, 2009
What type of oil do l use for a Troy built walk behind lawnmower?
Typically mowers come with a straight 30 weight oil.
Sep 19, 2017 | Troy Garden
Lawnmower Makes Squealing Sound when Self-Propell is Used
if you take it apart there will be no warranty . take it to where purchased and get it repaired
Jul 21, 2015 | Troy Bilt 5.5hp Self Propelled Mower
I have a Troy-built gtx2654 lawnmower with a Birggs & Stratton engine mod 47777 typ.0229E1 want to troubleshoot charging sys.
You can test the charging system by starting the mower and then unhooking the negative terminal from the batter, if the mower stays running, the charging system is working, if it dies immediately the charging system is faulty, you can also use a tester at the engine to test the voltage at the connectors
Oct 12, 2013 | Briggs & Stratton Briggs Stratton...
Deck belt broken, l need a diagram to replace new belt on a Troy bilt riding lawnmower, 42 " cut 20 Hp, model # 13AP60TG563. Thanks
You will find the diagram on the left side of the deck as you sit on tractor by left foot. It will be located under the foot pedal that has the routing diagram specifically for your Troy-Bilt mower model. Note that owner's manuals may not have the most current schematic.
Also you can check this link to download the diagram:-
http://www.seapyramid.net/rt/belt-diagram-troy-bilt-riding-lawnmower/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
I have a troybuilt push lawnmower with a honda motor, I was wondering where the oil plug was where I can drain the oil.
It is under the mower, you will need a 3/8 ratchet and extension to take it out...make sure NOT to tip the mower over, you will have to raise it, but make sure the spark plug end stays up!!!
Apr 25, 2009 | Garden
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
179 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
