Question about Toshiba Satellite A135-S2276 Notebook
External speakers I attached an external monitor to the laptop and now the speakers do not work.I received an external speaker with the monitor and i would like to know how to attach it.Can I plug it in to the headphone outlet or is htere a better solution. Please
  • okos Nov 09, 2007
    Thanks, I attached the speakers now the only problem I have is that the sound is very weak.
    I have gone into the control panel and adjusted all it still weak. I have modified that it knows it is aspeaker and not a headset still very weak.
    Any suggestions
    Please help
  • okos Nov 09, 2007
    I have dne all that and it still faint
You should right click on the speaker icon in the tray on the right hand side of your task bar (forget if that is what it is called) and make sure that all of the settings are high enough (Open Volume Control). Specifically the "Volume Control", "Wave Control", and "CD Control". If the problem is that your laptop cannot power the speakers you can always buy either powered speakers or USB connected speakers.
Posted on Nov 09, 2007
  • 31 Answers
You should be able to attach the speakers to the headphone outlet with no problem.
Some monitors do not have speakers (my HP monitor does not). The sound has come out of some external speakers attached to the tower. Or maybe you need to access the monitors on-screen menu to turn the speakers on (if they have speakers). Or maybe you can access the monitor speaker control through the PCs Device Manager option (this is where all external components attache to the PC can be viewed, and sometimes changed).
Aug 13, 2014 | Gateway LP2207 LCD Monitor
CB in Receive Mode Plays Out the PA Speaker
no,its supposed to work that way so you can monitor it while you are outside your vehicle.
May 04, 2014 | Radio Communications
My laptop speakers are not working but there is sound when i attach headset
once cause is that your onboard speaker on your laptop was already been busted, My suggestion is better to use headset or external speaker. Or also try to navigate control panel and go to sound settings then check if their is an option for internal speaker being used. If not then better to use your headset or external speaker. Hope it helps thanks.
Sep 13, 2011 | HP 530 Notebook
Can I attach external speakers to my LC321SS9 ? If yes, what kind ?
Yes, you can attach speakers to the laptop (through headphones Jack/ output)
Any Computer speakers can be attached. You can simply add stereo speakers or 2.1 or even 5.1 Channel Speaker system (which have woofer as well)
Hope it helps! Good Luck!
Apr 19, 2011 | Computers & Internet
How do you hook up a external amp to a yamaha HTR-5790 av receiver? Do you have to change any settings?
Elaborate a bit on what you're trying to do if this doesn't work for you.
This unit has Pre Outs near the center of the rear panel for all audio channels which will allow you to use external amplification for any speakers you wish to use and the receiver will still control the volume.
See #12 on page 10 of the manual. Try
Just run RCA cable(s) from the desired Pre-Out jack to the input(s) on the external amp with its speaker(s) attached. Set the external amp's volume (if it has one) to very high, then leave it alone. Run through the Yamaha's speaker location and volume settings to level-match the external speakers to the rest.
If you want to simultaneously use the Yamaha-attached speakers for the same channels as the external amp you'll have to match the like channel volumes to each other using a volume control on your external amp, then level-match them as a unit to the other channels.
Dec 23, 2010 | Yamaha Audio Players & Recorders
Paradigm Monitor 9 v4 tweeter not working.
speaker is must likely blown. check to see if another tweeter works at that connection.
Feb 14, 2010 | Paradigm Monitor 9 Speaker
Connecting computer speaker to a receiver
Which output section of the Denon are you using? Tape monitor out? And are you getting sound through the speakers (not the PC speakers) that are attached to the Denon speaker terminals?
Oct 26, 2009 | Denon AVR-1601 Receiver
No speaker output from television input. Other inputs (DVD, CD) work fine.
Check to make sure you have the TV input connections in the correct
slots. Sometimes there are two possible inputs for a TV. One being a monitor 1 and the other a monitor 2. There could also be speaker select buttons on the receiver that correspond to each.
Also check the TV audio settings to make sure the output connections are sending an audio signal, also known as external speakers.
Jul 29, 2009 | Denon AVR-1082 Receiver
Need help getting audio to play on my HP 2009m monitor which is connected to my HP laptop.
The speakers on the monitor will work only when the sound output from the laptop is connected to the monitor speakers. Please make sure that you connect the cable from "Audio OUT" (generally Green colored port where you connect your headphone or external speakers) on the Laptop to the "Audio IN" port on the monitor.
Please let me know if it works.
Thanks and Regards,
Apr 21, 2009 | Computers & Internet
Connect Bose 901 eq to Denon avr 2807
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the Tape Monitor with any type of stereo-only sound processor (non-Bose EQ, dbx expander, etc) and the various DSP options to spread 2-channel analog source material around the room. I have a whole stack of analog processors, tape and CD recorders slaved to my single Tape Monitor and then into a dbx400x Program Route Selector. It not only expands my Tape Monitor to handle nearly unlimited external devices but it makes routing for listening or recording easy with simple pushbuttons. But I digress...
The good news. I have a setup similar to what you want to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs (probably like yours) so I can drive up to 6 external amplifiers if I want to (I drive 4).
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front L&R Pre Out >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> NEW amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Oct 19, 2008 | Bose 901 VI Main / Stereo Speaker
Toshiba Satellite A135-S2276 Notebook Logo
136 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
