Question about Acer Computers & Internet
It shutdown on me while i was on it and now it is not turning on and i have took the battery out and put it back in and it still does not switch on
I just got a Toshiba T135 laptop just this week and so far so good, except for one thing. Whenever I shutdown the laptop and leave it for over an hour or so, and turn it back on, everything turns on (as in...
This is not normal behavior for this model of laptop. I would contact the manufacturer to have it repaired under warranty, as this is likely not a software issue.
Mar 14, 2011 | Toshiba Computers & Internet
Any schematics available for a APC Back-UPS Pro 650PNP? I installed a new battery (yes correct polarity) and smelled a little smoke. It was unplugged during the battery swap. I took the cover off but...
hi, i don't have the schematic but, i think if you connected the batteries okay and had switched off the machine then it should work. when switching on there are two sounds that come, first its a beep, if you release the ON SWITCH the UPS will just do a self test then shutdown. to switch ON the UPS completely don't release the on button until you hear a second beep, if you release the ON switch when this beep is on, then the UPS will be ON completely.
Nov 09, 2009 | APC Back-UPS Pro 650 UPS System
Yamaha 6500 watt diesel runs but usually shuts
First thing to monitor is the fuel solenoid power. See if it is the thing that goess away to cause shutdown.
Tracing this back there is only a few things that control this: The battery, the low oil shutdown switch, and the run switch, and associated wiring.
If I were to ventture a guess, I would put money on the low oil shutdown switch.
Aug 24, 2009 | Taylor Skid Mount Diesel Generator Set 30...
Reset psp,once turned on doesnt work?.
Looks like you might of run an update of some sort from the UMD disc or memory card. Take the battery out and then put it back after 15 mins.
If it still doesnt work im afraid you may of bricked it by forcing shutdown on the PSP.
There are people on ebay who might be able to help if you cant get the PSP to work.
Just type 'bricked psp' into search and tell the person what happened. It shouldnt cost more than £15 to sort the PSP out.
Jul 10, 2009 | Sony PlayStation Portable (PSP) Console
Last time i normally shutdown the laptop when i switch on next time it didnt poered on
Hi there.
Take the battery out of the laptop and try it on AC power only, if it boots up turn it off again, put the battery back in and power up, if it doesn't boot the problem is the battery.
Good luck and thanks for using Fixya!!
Mar 16, 2009 | Acer Extensa 5620 Notebook PC
I cant get my sansa mp3 playr 2 turn on?
i had this problem today-though mine sounds a little different. i need more info to correctly answer this, but i'll give it my best shot. when i tuned my Sansa on, it said 'battery too low. system shutdown' so i charge it same thing. here's what i did.
1)carefully unscrew the back off
2)you should see a big white thing with all ths Japanese kanji and what not on it. this is the battery.
3)what i did was i took out the battery since it is customer replacable and i put it back in. the same one. it works now.
~loli~
Dec 13, 2008 | SanDisk Sansa e250 MP3 Player
Axim x3 power switch light flashes green constantly
as far as I remember its the wireless working, if you press the button on the far right u can disable the wireless..this will turn off the flashing green light.
May 30, 2008 | Dell Axim X3 Pocket PC
Problem with black screen
have you try to check your battery? try to put some colling fan to your laptop to avoid hybernation of your notebook..
Mar 26, 2008 | Computers & Internet
Digital camera wont turn on
I just answered another question similar. Try that.
http://www.fixya.com/support/t244396-wont_turn
If it HelpsYa, please choose FixYa! ThankYa! =)
Nov 30, 2007 | Fuji FinePix A360 Digital Camera
Sansa 2.0 mp3
Key lock means the HOLD switch is on.
Slide it the other way.
Best of Luck.
Nov 27, 2007 | SanDisk Sansa c150 MP3 Player
Computers & Internet Logo
15 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
